AAAGGGHHH!!!!!! 2.7 Wowes :-(
Widge
Post Wed Aug 10, 2005 9:32 pm
Right, got my donor engine to pieces yesterday, thinking I could throw the eta crank in on the old bearings today for measure up etc... so I can then plan the next step & know what sizes I'm talking about to the machinist.
So I put the crank in, having left the conrods and pistons in the bores. Put a crank cap on each end, and connected the con rods. Having oiled the bearings it then turns etc, so I turn the block over (working on the floor till my engine stand arrives) to see how much the pistons are sticking up.........and they aren't :oops: WTF ok so I turn it, and unlike the 2.5 crank that came out the pistons are 1mm lower down the bores :cry: How can this be????????????? - I got it off Ebay :x
However before I jump to coonclusions, I cannot work out what the crank is from, what combination of 2.5 pistons, 2.5 rods, 2.5 block and ?? crank will have the pistons lower down the bores?
Also what do you lot think, re ebay, because it looks increasingly like I have been sold a 2.5 crank under the impression it's a 2.7 one??? it was probably 3 months ago.
Any way I'm off out to take a pic to put up, any support or comment gratefully recieved aaaaaaggggggggggghhhhhhhhhhh and the plan was only just starting :-x
Here we go this is at TDC -
By my calculations the top edge of the pistons should be 3mm clear of the block. Check out his description http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 4549072666
Here for sale is a 525i ETA crank which i bought myself for 75 pounds off a guy when i was doing my 2.7 engine conversion
I really hope he means 525e eta, there is no such thing as a 525i eta, is there?
Sjoerd320i
Post Wed Aug 10, 2005 9:47 pm
nope,
sorry to hear that mate :(
Widge
Post Wed Aug 10, 2005 9:49 pm
Anyone know where the part numbers are on a crank????
bigdek
Post Wed Aug 10, 2005 10:22 pm
is the block definately a 325 block and not a 320 ?
E30Adam
Post Wed Aug 10, 2005 10:28 pm
bigdek wrote:is the block definately a 325 block and not a 320 ?
If it was a 320 block, the pistons wouldn't fir because it's a narrower bore.
I think the crank you've got isn't an 525 eta one dude.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
bigdek
Post Wed Aug 10, 2005 10:29 pm
he only swapped the crank though left the pistons and rods.
E30Adam
Post Wed Aug 10, 2005 10:30 pm
bigdek wrote:he only swapped the crank though left the pistons and rods.
Ah yes, misread that part.
I'd still say it's the wrong crank though.
bigdek
Post Wed Aug 10, 2005 10:33 pm
probably, just don't know the origin of the block thats getting used.
Disaster either way i suppose :(
Widge
Post Wed Aug 10, 2005 10:56 pm
The block is definetly a 2.5 as I was told it was when I got it (yeah like that's reliable) and it has a 2.5 head and pistons, and it has the steam holes between the cylinders, and it had 2.5 inlet and TB etc....
Must be the wrong crank, I just can't work out what crank would do that, as the pistons have definetly moved down when at TDC compared to the crank I took out.
I have emailed the guy will await his reply tomorrow, I bet he hasn't got a clue and was just sold it!!! Arrgggggghhhhhhhhhhh :x
Part numbers anyone, I have a feeling the cranks don't have them, cos it would clear up the problem once and for all.
bigdek
Post Wed Aug 10, 2005 11:00 pm
must be some way of identifying it .
if not by part no then by measureing it ?
Poss go to local bmw garage or specialist tomorrow and ask one of the mechanics ?
Widge
Post Wed Aug 10, 2005 11:06 pm
I haven't got any vernier calipers that aren't :wan: and anyway it's much easier said than done measureing from virtual centre to virtual centre, especially when you're only talking 6mm differance. Oh balls this has totally cocked up my project, I'm skint at the mo and was quite happy that I had the bits to be getting on with.
billgatese30
Post Wed Aug 10, 2005 11:11 pm
mate, do'nt measure from centre to centre, try and measure from left hand edge of bore A to the left hand edge of bore B, might be a bit easier than doing centre to centre as you actually have something reasonably close to line up with
Widge
Post Wed Aug 10, 2005 11:15 pm
Sorry mate I ment measuring the crank not the bores. I am damn sure it's a 2.5 block.
Jimbob
Post Wed Aug 10, 2005 11:20 pm
Is it worth checking the block number at your local stealers tomorrow mate?
Widge
Post Wed Aug 10, 2005 11:22 pm
The block really isn't in doubt mate, it's the fcuking crank that's the unknown. I definetly know it's a 325 block as hte inlet manifold and TB I got of it were 2.5 items, also it's head now sits on Craigieeb's nitrous 2.5 and that's working fine, which if it was a 320 or 323 head it wouldn't.
Jimbob
Post Wed Aug 10, 2005 11:24 pm
Fair enough
billgatese30
Post Wed Aug 10, 2005 11:26 pm
sorry mate, thought you were on about the bores
Widge
Tossing fcuking ebay cretins aaagggghhhhh
ian332isport
Post Thu Aug 11, 2005 12:20 am
Are there any part numbers or marknigs on the crank ?
Ian.
Widge
Post Thu Aug 11, 2005 10:10 am
Not that I can see Ian, I will have a look in the light today, but when I got it I tried to trck them down to confirm it was an eta crank before I left him feed back but I seem to remember there aren't any on the crank.
E30Mark
Post Thu Aug 11, 2005 10:41 am
Whats the throw on the crank?
Measure the difference between the pisons at TDC and then at the bottom of the stroke...
the eta crank is a 81mm stroke i believe.
Widge
Post Thu Aug 11, 2005 10:45 am
For fcuk's sake why didn't I think of that!!! :oops:
I was thinking about doing it with the crank out of the block.
Cheers will do - the Eta is 81mm your right the 2.5 is 75mm.
E30Mark
Post Thu Aug 11, 2005 10:51 am
Yeah i usually like to do things the hard way too! .....
It's the old mechanical engineer in me!
Now you've got me thinking about the old 318is engine i have sitting out back. Might strip it down and see what other cranks / pistons will fit in it.....
zaust
Zone day release
Post Thu Aug 11, 2005 11:14 am
would it be worth looking into a shorter rod??
M30 Tech 1 Touring on gas.
Widge
Post Thu Aug 11, 2005 11:17 am
I think thou art missing th point Zaust!!
StuBeeDoo
Post Thu Aug 11, 2005 11:23 am
Dave.... As ever, I stand to be corrected etc, but if you go the 2.5 > 2.7 route as you are doing, don't you have to have the block decked?
Stuart.
Widge
Post Thu Aug 11, 2005 11:40 am
Yes, but only if you use the 320 con rods which are 130mm long. I am using the 325 rods which are 135mm long, which with the 325 pistond and the 81 mm crank should make the pistons stick up by 3mm. H ave just measured the stroke, abeit badly, and as far as i can see it's between 65-70mm, I did do it with a bit of wire and a tape measure, where are the vernier calipers??......
StuBeeDoo
Post Thu Aug 11, 2005 11:44 am
Widge wrote:as far as i can see it's between 65-70mm
Don't like to worry you, but the 320i crank is 66mm stroke!!!
Widge
Post Thu Aug 11, 2005 11:50 am
That's the fu*#ing one then!!!!!!!!!!!!!!!!!!!!!!1 :x :x :x :x :x :x Cheers Essbee I haven't been able to find the specs, I can get on to the tit who sold it to me now. I had a sneaky it would be from a 320 or a 323.
StuBeeDoo
Post Thu Aug 11, 2005 11:52 am
:cry: Gutted for you Dave!! :sad:
E30Mark
Post Thu Aug 11, 2005 11:53 am
http://www.unixnerd.demon.co.uk/enumber.html
check out the above for the different crank strokes etc
Widge
Post Thu Aug 11, 2005 11:55 am
I just want my Ԛ£35 back to put towards getting another crank.
Widge
Post Thu Aug 11, 2005 12:21 pm
Of corse it is now past the 90 day ebay complaint deadline, aagggghhhhh :x
Toby_Unna
Boost Junkie
Post Thu Aug 11, 2005 12:43 pm
don't mean to kick u when ur down but maybe u should change ur sig from eta crank to 320i crank! :P
just mail the seller and ask what's going on, u have their address?
first thing is though, measure the stroke accurately. an error of 5mm is rubbish, if u can't find the vernier just get a metal ruler with increments starting on the edge and put that down the bore!
Widge
Post Thu Aug 11, 2005 12:48 pm
Yeah yeah - I'm looking for the verniers.
I will change the sig - ebay tossers :x
