s50 prop problems
buster
I have trashed the 6 speed gear box and i am changing it for a 5 speed box. I have fitted the 3.25 diff and got what i thought was the front part of an e36 328 prop which i was told would fit onto the rear part of the 325 prop but it doesn't.
So appart from an e30 m3 prop does anyone know what will fit ?
Maybe the complete 328 prop ?
- Homo Hair
Don't know who told you the 328i front with 325i rear as it is wrong
Complete 328i prop will fit
buster
I got it from bob s . the uj must be on the rear part of the prop on the 328 also,unlike the 325Jhonno wrote:Don't know who told you the 328i front with 325i rear as it is wrong
jaistanley
You need to fit the E30 centre bearing to the E36 328i prop.. Then it bolts straight up....
UweM3
sorry to hijack this but how does one remove the bearing??jaistanley wrote:You need to fit the E30 centre bearing to the E36 328i prop.. Then it bolts straight up....
I am not sure but think that my M3 prop is on the long side for my engine swap (centre bearing is at the end of the slot holes)
and though If I turn it round it would give more room.
@buster, sorry to hear about your gearbox problem.
- Homo Hair
Your M3 prop should be a straight fit Uwe! I am running the same.. You might need to adjust the length slightly by loosening the collar and then sliding it up the splines slightly
The centre bearing is held in place by a circlip and is fun to get off.. Ended up cutting Jai's off
UweM3
I pushed it all the way in already. Just feels like there is some preload. My centre bearing was replaced not long ago and I wasn't able to remove it. I removed the circlip but didn't want to get too violent.Jhonno wrote:Your M3 prop should be a straight fit Uwe! I am running the same.. You might need to adjust the length slightly by loosening the collar and then sliding it up the splines slightly
Some drop off, others need serious abuse, big hammer and big chisel usually work wellUweM3 wrote:I removed the circlip but didn't want to get too violent.
UweM3
And can you still use it after that?DanThe wrote:Some drop off, others need serious abuse, big hammer and big chisel usually work wellUweM3 wrote:I removed the circlip but didn't want to get too violent.
I usually fit a new one
- Homo Hair
Wierd.. Should bolt straight up! Mine did...UweM3 wrote:I pushed it all the way in already. Just feels like there is some preload. My centre bearing was replaced not long ago and I wasn't able to remove it. I removed the circlip but didn't want to get too violent.Jhonno wrote:Your M3 prop should be a straight fit Uwe! I am running the same.. You might need to adjust the length slightly by loosening the collar and then sliding it up the splines slightly
buster
has anyone got either prop for sale ?
- Homo Hair
buster
its advertised as a m3 prop but looks like an e36 328 one to me.does the m3 not have the uj in the same place as the 325, ie on the front section?
ps.thanks for the link,pricey if it is a 328 one
jaistanley
The E30 M3 prop looks identical to a 325i one, apart from having a larger guibo (lengths might be nominally different). If it has the U/J the other way around it'll be a 328i one..
Jai
Jai
jmc330i
Not quite, the U/J's are on opposite sides of the bearing....jaistanley wrote:The E30 M3 prop looks identical to a 325i one
Top prop is from my 325i, bottom one is an E30 M3 one (without the vibration damper thingy).
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
328i prop is similar to the E30 M3 but has a lumpy bit around here
jaistanley
My bad.. I could have sworn Dan's E30 M3 one isn't like that. Guess it is!
buster
thanks guys.that photo says it all
UweM3
jmc330i wrote:Not quite, the U/J's are on opposite sides of the bearing....jaistanley wrote:The E30 M3 prop looks identical to a 325i one
hmmmm.....
I will have a look tomorrow but believe my M3 prop front section has the bearing and the U-joint. (like the above pictured prop)
EDIT,
just had a look and my prop has indeed the U-joint and the bearing on the FRONT section
RoadHazard
If I get a 328 prop, does it matter whether it came from an auto or a manual?
Edit:
Forgot to add. I'm planning to use 5-speed M3 box with E30 M3 diff. These will mate with S50B30.
Thanks.
Edit:
Thanks.
buster
yes it matters,it needs to be a manual prop.
glenn
- Engine Transplant Services
hello andy,
i have this breaking..........
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :MESELX:IT
would the prop be ok for you?
i've just gone outside to check if it's the same as in james's picture, and it's slightly different to both ! there's a sticker on the prop near the guibo, with....
BMW E46 7 523 929 A102
any good to you?
any good to you?
RoadHazard
buster wrote:yes it matters,it needs to be a manual prop.
Thanks buster. I also forgot to mention my car is 4dr. Same prop as in 2dr.?
buster
Glenn,
i've got one now thanks Glenn.All sorted a while ago.Thanks anyway.
Roadhazard,
Yeah the same.
Roadhazard,
Yeah the same.
glenn
i have removed the prop off the s14 touring i was breaking, as i've sold the prop.
the rear part is an ordinary e30 rear section, and the front is marked up as an e46 320d !
i thought i'd post my findings here, as its an alternative for anyone thinking of a prop for the s50/5speed conversion
tomson
I have two E30 M3 props and they are different as you have found...UweM3 wrote:jmc330i wrote:Not quite, the U/J's are on opposite sides of the bearing....jaistanley wrote:The E30 M3 prop looks identical to a 325i one
hmmmm.....
EDIT,
