FUEL GAUGE GOING MAD WITH LIGHT ON
leee111
Thu Jun 25, 2009 8:39 pm
AS ABOVE I PUT A ENGINE my sport now when i start it the fuel gauge goes to 3/4 and the light is on now my car is nt 3/4 full more like the light to be on any ideas
Thu Jun 25, 2009 8:48 pm
Sender unit, or most likely the nut on the cluster behind the guage can work loose, so tighten it and see how you go from there.
Grrrmachine
E30 Zone Wiki / Team Member
Thu Jun 25, 2009 8:59 pm
If you have two senders (one in the fuel pump, the other alone on the other side of the tank), when one breaks it can make the fuel guage crazy. If the light is coming on when it should, it suggests the one in the fuel pump is working ok; take out the other one (round hatch, under rear bench, passenger side), and do a resistance check on it. The resistance wire inside can break and short out on the aluminium housing, causing the sender to massively over-read.
leee111
Thu Jun 25, 2009 9:11 pm
bummp
paddyvw
Tue Jun 30, 2009 1:24 am
i have similar problm in my 320is. took out clocks. the nut was not lose. the fuel guage goes mad when up and down. i tried a in tank sender unit but that not problem
Dave_M3
Tue Jun 30, 2009 1:33 am
Same problem with mine too...
Fuel gauge works right sometimes and sometimes it could be at the 1/4 mark at half way :roll:
Didn't bother me too much as the range function on the OBC works properly but would be nice to find out why it does it anyway.
It's definitely a clock fault as other clusters work fine.
How about you just give me the clocks out of the 320 Paddy seeing as I wouldn't really mind a funny fuel guage :P
paddyvw
Tue Jun 30, 2009 2:05 am
will take te clocks out of my other 320is and see if that fixes it
