Hi
Can anyone please tell me how to fix this!
The electric windows basically only work when the doors are opened!
I think it is a fault somewhere with the green/gray wire, but where does it end up?
There is a positive signal when doors are open, but nothing with just the ignition?
Q
Electric Window Wiring - Windows work when door open only!!!
Comes from relay K5, via fuse 17. Do you have an electric roof? That shares the same supply.
e30_Turbo
- Boost Junkie
Not meaning to hijack this thread but.......
For weeks now I've had a fault somewhere in the heater blower/window circuit. Firstly the power flickers on and off (you can see the window switches and sunroof switch flickering
) when you drive normally. The blower does the same.
When stopped and the doors are closed, ignition on nothing at all.
When doors are open and ignition on the windows work fine but the blower does not.
Is there a relay that switches the power from the switches to the ignition?
To find a solution to this would make me a very happy man......
cheers,
Mark
cheers,
Mark
All these are fed from the K7 unloader relay. This relay and K5 are connected to be on with the ignition, but to drop out when the starter motor is engaged.
New relay in K& position might work wonders.
For "K&" read " K7".
e30325itourer
my car had similar problems turned out to be a bad earth at the fuse box
These two relays don't have an earth as such. Their earth connection is through the coil of the stsrter solenoid (smallest of the ring terminals on the starter motor).
A1BMW325iSport
was just gonna say what Brian said LOL,
Brian you know your autoelectrics pretty well then?
Was playing around with bulbs, batteries, switches and bits of wire at the age of four making circuits, so I've been told. Electrics have always come fairly easily to me. Bodywork and paintwork - there's a different matter alltogether.
A1BMW325iSport
ok cool mate, i been into electrics for years as well, always doing car stereo install and stuff, nothing 2 big or comlicated for me i seem to get there in the end and solve the problem.
It's the end result that matters. not the route.
M5pilot
Thanks for all your help guys - finally solved it
Bit embarressed actually, case it was the fuse
Well, its not my fault they used 2 different circuits for when the ignition was on and off!!
Q
Q
Quaser
That was me that wrote the above - not Sal!
He was using my pc yesterday
Q
Q
