Beemerlad's M52 Chromie
Post Tue Jun 02, 2009 8:44 am
Is that a confession? :D
**BANNED**
Post Tue Jun 02, 2009 12:50 pm
DanThe wrote:Is that a confession? :D
If you are refering to me,young man,no!
But the new GSF brake master that I bought in March has just gone back faulty.... :cry:
Post Tue Jun 02, 2009 2:01 pm
Dominitry wrote:When did you get a Supra?!
I haven't mate, it's my brother's, headgasket went on it in spectacular syle 2 weeks ago at 140mph :)
Post Tue Jun 02, 2009 2:02 pm
Just got back from the motor factors and got a large bleed nipple that will fit, gonna fill it with chemical metal too just to be safe.
djk
Post Tue Jun 02, 2009 2:39 pm
Are we going to have some sort of zone celebration when this thing is finally on the road? It'll be like the end of an era!
Post Tue Jun 02, 2009 2:45 pm
yeah, it'll be called a frag fest :)
Daf318is
Post Tue Jun 02, 2009 5:21 pm
E30BeemerLad wrote:yeah, it'll be called a frag fest :)
Can I have first refusal on the manifold then winkeye ! Still can't b'live that it actually fitted!
You can't break it - not after all this :eek:
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
Post Tue Jun 02, 2009 6:50 pm
E30BeemerLad wrote:gonna fill it with chemical metal too just to be safe.
Just to be sure you cant ditch the ABS? :)
Post Tue Jun 02, 2009 8:33 pm
Servo & master cylinder are off the car, sorted the spare outlet on the master cylinder now, but the problem I was moaning about with the brake pedal getting stiff and then releasing is the servo.
If I push on the rod from the back of the servo it goes in, then gets stiff then clunks & releases some more, the diaghphram seems to be sucking etc.
I tried this on the original servo I removed and it does the same.
Am I losing the plot here?
Post Tue Jun 02, 2009 8:49 pm
Is the rod in line? If its pointing off centre it wont be smooth, I noticed this while adjusting the pedal with no M/C fitted
Post Tue Jun 02, 2009 9:55 pm
this bastard piece of shit!
Had the servo off and on again, with the spacer in the end of the m/c I seem to have not that much pedal travel before it just goes solid, I have no fluid in at the moment, is that normal?
If i take the m/c off and then push the pedal I just get the spastic clunking again
FFS I just want to get this turd finished, even working on a school night and all that
Post Tue Jun 02, 2009 10:09 pm
With no fluid the pedal should hit the floor
Post Tue Jun 02, 2009 10:11 pm
in which case I'm going to close the garage and watch wheeler dealers as I can't be arsed with this turd tonight
Daf318is
Post Tue Jun 02, 2009 11:05 pm
Just be carefull with master cylinders and going all the way to the floor. Because they don't usually do this they can stick and seals break - speaking from experience :cry:
rix313
Post Tue Jun 02, 2009 11:10 pm
Liking the thread title :D
Post Sun Jun 14, 2009 10:01 pm
After spitting my dummy out on Friday when the lolipop bushes would not go back onto the mounting holes, I managed to get them back on by undoing the main balljoint and dropping the arms down, bolting up the lolipops and then smacking the arms back into position. So front ARB mounts now modified and ARB does not touch the downpipe, so it's back on 4 wheels again.
I also did the rings around the lights in satin black and fitted them back
Then I fitted these puppies
I'm very pleased with the look, will look better once the rest of the interior is back in and actually clean
Coming together under here too
I'm happy with the clearance underneath(this was taken with the camera on the floor) but I guess the first journey over the speed humps that litter the estate will tell
Not got the throttle connected yet as i fitted a new E34 throttle cable, but what bit is missing from the bracket on the throttle body here? I can't see it on realOEM. Must be some sort of plastic insert?
Then I tried to work out why the only door I can open or unlock is the driver door. I did the red/black wire mod to the multipin in the door (you can see the corrosion) but it made naff all difference
Think I'm gonna start another thread about this as it's bugging the hell out of me (not opened anything other than the driver door and tailgate since I got the car almost 2 years ago
So now I'm waiting on a brand new clio servo to arrive in the week so I can get the brakes sorted. I have some braided hoses to fit, which I may well do as the front flexis look a bit perished and the pipes are a bit crusty where they come through the innner wing on the front so I'm going to order some pipes from BMW for the front as they cost buttons.
Nearly there folks
:mad:
Dezzy
CR24v it's a lifestyle
Post Sun Jun 14, 2009 11:30 pm
Looking good mate they sit well in the engine bay dont they my E30 shell is coming home tomorrow as i have got rid of the e36. Just the servo that was the problem then?
Post Sun Jun 14, 2009 11:42 pm
Hopefully just the servo, it makes the clunk when no master cylinder there too
Post Sun Jun 14, 2009 11:46 pm
stick with it Lee it's getting there :)
I was local today (haxby) but couldn't find your number :mad:
a green soarer shot past me at the roundabout, can't be that many around there ?
Post Mon Jun 15, 2009 12:01 am
Silver E30 private reg AVO?
Post Mon Jun 15, 2009 12:09 am
E30BeemerLad wrote:Silver E30 private reg AVO?
was me :)
Post Mon Jun 15, 2009 12:12 am
Bummer
I'd been up the road at a retail park and was on my way to a motor spares place to get a new 1/2" extension otherwise I would have turned into Haxby.
I clocked the E30 straight away as there are few around here, looked nice mate
Post Mon Jun 15, 2009 12:22 am
E30BeemerLad wrote:Bummer
cheers, some great roads around by you :)
it looks good from a distance she needs a bit of therapy the rust is starting :cry:
went from york to liverpool clocked up 300+ miles today speedo is almost on 60k 8O
Jesus325iTouring
Frog freak !
Frog freak !
Post Mon Jun 15, 2009 8:31 am
Nice to hear your fitting French parts Lee,way to go to keep up the quality :wink: :wink:
Post Mon Jun 15, 2009 9:10 am
The Clio servo is made in Germany by Bosch :P
Daf318is
Post Mon Jun 15, 2009 9:38 am
It's a plastic insert that goes on the end of the throttle cable - I may have one. If I do I'll dig it out and drop it in the post for you :)
billgatese30
Post Mon Jun 15, 2009 9:23 pm
If daf doesn't have one Lee I definatley have one (just replaced it yesterday when fitting a new throttle cable)
Post Mon Jun 15, 2009 10:11 pm
Chris, as you are a dead cert, would you mind posting yours to me? I'll PM you my address. Cheers Lee
Daf318is
Post Mon Jun 15, 2009 11:05 pm
Got it on the desk here if you want Lee? It even has a piece of throttle cable still attached to it!! Can drop it inthe post first thing tomorrow if you want :)
Post Tue Jun 16, 2009 12:21 am
Can you do that Daf, Chris is posting me his, but just incase there is any difference or anything spazzy like that. Muchas gracias
MarkT
Post Tue Jun 16, 2009 8:04 am
Really looking good mate, enjoyed reading through this one. Got a deadline for finishing?
Omi
Witty custom rank.
Post Tue Jun 16, 2009 10:29 am
2011.
...or is it?
n1tr0_9
Post Tue Jun 16, 2009 10:40 am
That Cat is smirking at your efforts in typical Cat fashion. Get the car finished, then you can run it over! :twisted:
Post Tue Jun 16, 2009 11:13 am
Omi wrote:2051.
d6dph
Post Tue Jun 16, 2009 11:24 am
Jhonno wrote:
Omi wrote:2051.
Petrol will run out before this thing sees the road!
