wiring up standard electric arial
- e30-unit-soldier
I got a standart electric arial in my cab the black wire is grounded were does the red go? does it go to the blue arial output on the head unit?
MJJ_ZX6RR
- Contact:
Red wire needs to go to a fused, unswitched live - I went straight to battery +ve on mine as the batt is in the boot. Blue wire goes to the blue aerial output.
Martin.
Martin.
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
- e30-unit-soldier
Theres only 2 wires on it
Red and Black.
Red and Black.
MJJ_ZX6RR
- Contact:
An electric aerial needs 3 wires, +ve (red), -ve (black), signal feed from HU (blue).
I cannot imagine how it could work any other way.
Martin.
Martin.
It may earth to the bodywork, one should be a switchable (from the blue wire on stereo as you say) and the other a permanent live.
Doesn't sound like a Hirschman (spelling?) standard areial.
Does it have a maker's name?
Hirshman and Beru aerials have the three wires, permenant live, earth and switched live. Unless the aerial body is earthing through the retaining strip to the bodywork(have never seen this) then the three wires should be there.
