2.5 M50 500hp.
Gunni
Fri May 15, 2009 4:15 pm
Unfortunately the engine is sold and the owner needs it soon, so it´s coming out very soon.
I however will be putting in a M50 for my PlugN Play VEMS units baseline setup, as I will be designing them over summer for a big range of BMW´s
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
Gunni
Mon May 25, 2009 12:48 pm
Well engine is coming out soon,
So I´m getting a M50 instead.
I´m going to run it AlphaN on VEMS and use it as the development platform for my
plug&play VEMS ecu´s for later BMW engines.
Hate to see this monster 2.8 go but such is life.
Gunni
Mon May 25, 2009 6:32 pm
profit is more resonable than justice to quote the fat man on here!
stembo21
Mon May 25, 2009 8:06 pm
how mucj has it gone for
Gunni
Mon May 25, 2009 8:35 pm
The whole engine package has gone for 3800pounds.
Gunni
Mon May 25, 2009 8:36 pm
M50 turbo? winkeye
Gunni
Mon May 25, 2009 9:03 pm
I wish.
Just using the car as a test platform.
Gunni
Mon May 25, 2009 9:09 pm
Look forward to seeing the updates :)
rosscoe
Mon May 25, 2009 9:13 pm
By fek thats quick!!
Respect ma man indeed!
stembo21
Mon May 25, 2009 9:34 pm
Gunni wrote:The whole engine package has gone for 3800pounds.
is that with the vems ect
fowler
Boost Junkie
Mon May 25, 2009 9:38 pm
no way its too cheap who has got it gunni ????anyone we know
EX A-Tech Workshop bitch !!!
gone but not forgotten
Gunni
freshly rebuilt M20 2.8 engine + ancillaries + loom + VEMS + injectors, exhaust manifold, exhaust and so on.
Basically everything required to bolt this into a E30 , the owner had to find himself a M20 gearbox and driveshaft and gearshifting mechanism that´s it.
Gunni
Gunni
Mon May 25, 2009 9:39 pm
It´s nobody on the forum, he lives in Iceland.
Gunni
fowler
Boost Junkie
Mon May 25, 2009 9:41 pm
fair enough need to really get mine to a dyno pretty soon see if i can put down some decent power figures :cool:
Gunni
Mon May 25, 2009 9:42 pm
I´ll do a 500hp bolt in M50 package for 5k :)
Gunni
march109
Mon May 25, 2009 10:18 pm
How the hell could you sell it so cheap??
I'm still thinking naughty f/i thoughts but it would have to be a supercharger I think!
Gunni
Tue May 26, 2009 1:04 am
Cause my profit margin doesn´t need to be as high as other peoples.
Gunni
march109
Tue May 26, 2009 5:11 am
Gunni wrote:Cause my profit margin doesn´t need to be as high as other peoples.
I didn't mean it like that was just saying because it seemed too cheap for the quality of the work and results.
I'd be well happy paying that for 400bhp, £10 per 1 bhp (well a little less) tuning m20s isn't cheap you find me another 400bhp engine that will bolt right in for less and I'll buy it!!
Gunni
Tue May 26, 2009 9:55 am
That´s true, but then again
I did not buy
higher lift cam
custom pistons
stronger rods
any head porting work.
any "go fast, bling bling parts"
As those parts are not needed in a M20 of this powerlevel. A standard 2.5 with good compression can easily be made to perform just like this 2.8.
I think I could even do a better setup for the same money since I did this thing :)
Gunni
march109
Tue May 26, 2009 10:49 am
doh! Now I'm tempted but still veering towards the supercharger route!!
Gunni
Tue May 26, 2009 12:06 pm
why a supercharger?
A turbo system can be adjusted to provide boost exactly like a supercharger setup
Gunni
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Tue May 26, 2009 9:20 pm
Gunni wrote:why a supercharger?
That's almost true but depending on what you want from the car and what type of charger you go for I'm still sure that a turbo can never *quite* match the instant boost of a s/c.
I'm thinking small turbo vs. roots blower. Admittedly the turbo has the efficiency improvement over the roots particularly in the upper revs but there's still something to be said for the instant low-end grunt that makes a road car so nice to drive.
Not trying to be too contradictory as I've obviously got limited experience but I'm don't think I'm far wrong on the above.
Gunni
Wed May 27, 2009 12:25 am
I can see where your coming from but if you do have a turbo that punches well in the low end then more then likely it will not flow in the high end ,
And it will just as well suited as a supercharger if you just adjust the boost to suit.
Gunni
march109
Thu May 28, 2009 2:16 am
Frankly I'm not chasing big horse power and because I love my six branch manifold the easiest route to more power is a supercharger.
rosscoe
Thu May 28, 2009 10:24 pm
Gunni wrote:I´ll do a 500hp bolt in M50 package for 5k :)
wat could you do with an S50 B32 then ??
Gunni
Fri May 29, 2009 12:07 pm
Tricky stuff as the compression is relatively high.
So even the thickes decompression plate isn´t a good idea.
So it would have to be custom pistons and then stronger rods would be a good move for something serious powerwise.
even for 500hp a custom piston is the only option to keep things safe.
Then it´s basically what turbo has been selected and the power achievable with that.
But a S50 is nothing like a M20 or M50 to modify.
The VEMS usable on M20´s and M50´s would mean that the engine would have to have the vanos locked. or a ecu that is ALOT more expensive bought.
A s50 - 500hp would actually cost more then a M50 - 500hp
Gunni
oakey
Fri May 29, 2009 1:10 pm
^ What about an m60 then? Surely they would take well to a bit of boooostage?
Gunni
Fri May 29, 2009 1:56 pm
They are cousins of the S62 wich does not hold well to excessive power or rather torque as the crankcase isn´t suited or designed for it.
I haven´t yet heard of a long term usage of a 700hp+ S62.
Saying that I think a FI M60 would be a massive treat and fun to drive.
282hp stock, 560hp should be rather easy with about 1bar of boost.
But if the torque is keept in check then it should last fine.
Meaning more power would have to come as a function of rpm´s
So maybe a uprated cam would help it even further .
Gunni
bigbhpwannabe
Fri May 29, 2009 7:55 pm
hi gunni , will the manifold used in this build be the new design for top mount rhd cars if so is there any sort of time scale and will the price remain the same ? thanks gary
325i 4door turbo sleeper -
big turb
e36 carbonfibre wietech strutbrace for sale . 07919173179
Gunni
Fri May 29, 2009 8:03 pm
There is not going to be updated TCD top mount manifold unfortuanetely.
I´ll be making manifolds, split pulse out of mild steel for 450pounds now.
M20, M50 and M30 in E30 rhd.
ment for Holset HX35´s
Gunni
bigbhpwannabe
Thu Jun 18, 2009 8:20 pm
you gonna post up some picks then :D
big turb
no1_jazz
Thu Jun 18, 2009 10:37 pm
lovely 1 day
Gunni
Thu Aug 06, 2009 6:49 pm
Well it´s getting a M50 soon.
Pics as things happen.
Gunni
Gunni
Sat Aug 22, 2009 8:32 pm
I´ve decided to do another customer
build it and test it job.
This time it´s going to be a
M50B25 built for a E30 chassis and M20 gearbox setup.
M50B25 - new bearings, rings, oil seals and gaskets
MLS for lower compression
Head fully checked
ARP 2000 head studs.
TCD Stage III kevlar M20 clutch
"24x12x3 Intercooler
50mm blow off
60mm wastegate
tubular split pulse top mount manifold
Custom HX35
"3 downpipe
"3 stainless exhaust
VEMS ecu
60lbs injectors or bigger
Boost control in cabin.
Walbro fuel pump
944 brake booster
eletric fan conversion
custom M20 gearbox holder
and gearshifting mechanism.
Dyno tuned, road tested.
I´m building this for 4k pounds.
Customer will need to get his own gearbox, radiator and driveshaft.
The power will be 500hp at about 1.4-1.7bar boost
Full boost by 3750rpm.
So watch this space :cool:
Gunni
Sat Aug 22, 2009 10:13 pm
Subscribed :D
Sounds immense, kinda thing i'd be looking for :twisted:
