m40 to m42 conversion
Elecblondie
Post Wed May 20, 2009 3:12 pm
mt1104 wrote:make sure you have the right one for the gearbox though, I get sent the wrong one by ECP but luckily the one in the engine was the correct size so I just greased it up and put it back in.
The exhaust from the e30 318is is needed though, I modified my m40 one and tbh was more hassle than it was worth.
Told you it was more hassle than it was worth at the time IIRC. :wink:
robbo86
Post Sat May 23, 2009 2:23 pm
Thats a pig to track down unless your made of money. In the end I just kept my scorpion cat back from my m40 which was still bolted up to the m40 front section. As there was a few feet of m42 front section (it had been cut just before the cat/silencer) I chopped 2 slots in the m42 front section, chopped the m40 front section to match, sat one inside the other, exhaust paste all round and a 2 inch u bolt to clamp it down. Works fine IMO.
jon552
Post Sat May 23, 2009 4:58 pm
exactly the same as what i done M40 exhaust slots niceley inside the m42 down pipe then just clamped it and welded it up
jon
Elecblondie
Post Sat May 23, 2009 5:13 pm
I must have been lucky :) Picked up an IS exhaust for £50, I thought it was worth it.
robbo86
Post Mon May 25, 2009 1:48 am
Only trouble with mine is the back box is rattling against the body..... its bloody annoying and one of those piddly jobs I need to get round to sorting.
