Handbrake parts
Looking for genuine BMW parts at discounted prices? Try here!
C33
Post Wed May 20, 2009 9:10 pm
Is it still possible to get the "Spiral pin with compression spring" part number 34406751588 as an individual item or do i have to buy the whole spring repair kit #34419064266
Regards
Iain
E30Mark
Post Wed May 20, 2009 9:27 pm
From my experience the spring repair kit (Spiral pin) doesn't fit / work on a E30! I even asked our local dealer how they were supposed to fit, and there technicians said they didn't know :?
If your original back plate is OK then hopefully Cotswold can supply you with just the original spiral pin 34406751588
PM for details
C33
Post Wed May 20, 2009 9:33 pm
Cheers, I'll wait to hear from them, I was investigating some rear axle noise, took the disc off and found one of the pins bent 90deg and a bit ground off sitting in the bottom of the drum. :S Everything else seems ok though.
Regards
Iain
Cotswoldbmw
Post Fri May 22, 2009 3:06 pm
Hi Iain
if you want the pin then they are still avalible at £0.75 each
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
