Stereo mute for mobile phone
Guest
Post Wed Aug 03, 2005 9:34 pm
Well you probably guessed the question!! :D
Just installed a hands free kit and it has a yellow wire for the stereo muting function. Anyone know which wire it connects to on the stereo? I have a relatively new head unit SONY CDX-F5550
smithy318i
Post Wed Aug 03, 2005 9:54 pm
There should be a connector on the back if the head unit marked as TEL.
it may be behind a plastic cover plate. Mines over 4 years old and mine has one, so yours should (if it aint crap)
if it doesn't your stuffed.
smithy318i
Post Wed Aug 03, 2005 9:56 pm
Hmmm. Very nice!
Guest
Post Wed Aug 03, 2005 11:21 pm
I'll have a look, I know none of the wire were marked as such. Any other ideas anyone?
smithy318i
Post Wed Aug 03, 2005 11:26 pm
I had a quick look at the tech spec on amazon and it says nowt about phone mute.
Guest
Post Thu Aug 04, 2005 9:40 am
Its ok I found it! there is a wire from the connectore marked "ATT" this is what they called the telephone attenuator. I initially assumed it was something to do with the aerial :oops:
Cheers for help mate
smithy318i
Post Thu Aug 04, 2005 10:17 am
the ATT button on the front of mine is brill. I use that rather than screwing around at the back of the radio (plus the radio is glued in place)
tourer-dan
Post Thu Aug 04, 2005 3:44 pm
You can check by running each 'spare' wire to earth via a 2A fuse. When you get the correct one, you will see the display saying 'mute, phone' etc.
Just make sure you have the connection fused and be prepared for some shorting.
edit: I just realised you found it anyway. this might help someone else tho......
Ziggy
Post Thu Aug 04, 2005 4:16 pm
Glad you sorted it :thumb:
Anyone know what signal the hands free kit sends down that wire? Would love to use it to let my pocket PC mute the stereo when the satnav says something...
Jos
Post Thu Aug 04, 2005 5:49 pm
Probably just a drag to ground or drag to 12V signal, simple thing would be to put a meter on it and ring the phone.. See what it does..
'94 e36 tree climber
Ziggy
Post Thu Aug 04, 2005 7:57 pm
Jos wrote:Probably just a drag to ground or drag to 12V signal, simple thing would be to put a meter on it and ring the phone.. See what it does..
Would do... but I ain't got one! :lol: Anyone else fancy trying it out?
