First out were the boot carpets. Revealing a few bits here and there but it's not in too bad shape. There's a patch been welded before which has a lot of surface rust but it's still solid enough...
Slightly more concerning was this bit around where the fuel filler pipe exits the rear of the boot area...
And another bit on the outer inner wing...
Then out came the rear door cards to see what was behind this bit of rust on the outer arch..
Lo and behold...
This is not half as bad as the arches on the 325 which I managed to get repaired so I was still feeling quite chuffed with just one or two bits of easily repairable stuff.
Next out was the carpets. They were a bit damp and stained so I fully expected to find some floor panel issues.....
I removed the dreaded mudflaps a little while ago only to rip a sizeable hole in the nearside lower wing... After removing the front wings the holes just kept getting bigger, and bigger..
Nearside...
Offside, not quite as extensive, but pretty bad all the same...
Now normally when I have read threads like this before, at this point there usually follows the question, 'should I frag it or should I restore it???'
Well, despite the fact that this is a lowly bog standard M40 I am still going to attempt to save it, because,
1. All of the mechanicals/brakes/electrics etc are A1
2. It's a dolphin grey 2 door with no sunroof
3. My nephew can get the use of it in it's current set up for a bit after passing his test
4. Once the shell's integrity has been restored, and the boy has got his own motor, I'd like to tackle an M50 conversion. This would be an ideal lightweight shell for such a project.
So having decided to save this one, the question is how? The two big holes around the jacking points are obviously going to be the most difficult to sort.
I've never done any welding before but I'm about to learn I think. It's been something I've wanted to try for a long time and I think I have myself a guinea pig!!
