E30 M50 conversion temp sender?
kerrie
Hi
I have completed my M50 conversion and the temp gauge on the e30 is not working with the M50 sender?
What are the options?
I read somewhere that the M3 e30 temp sender fits the same threads?
tommy22
get the brown temp sender for a m20 and it will work
kerrie
Thanks Tommy22
daniele30
which temp sender on m50 should i remove?
the black one or the blue one ?
penton08 wrote:the blue one mate!
Blue one is for the ecu, black one is for the gauge
Confirmed! It won't run very well with the blue sensor replaced by a brown one (at least it won't when it gets up to temperature!)DanThe wrote:penton08 wrote:the blue one mate!
BigBavarian
Penton really hope you got it right on yours then mate!?
Richard
Richard
penton08
it is now!!! i thinkBigBavarian wrote:Penton really hope you got it right on yours then mate!?
BigBavarian
Good good, changed my temp sender today so my gauge works, only had the m50 in for 6 months! just got round to it and i remembered why i hadn't done it. Its an arse of a job with the engine in the carpenton08 wrote:it is now!!! i thinkBigBavarian wrote:Penton really hope you got it right on yours then mate!?
Richard
Richard
- **BANNED**
Just to confirm,it's the brown sender that requires changing,you need an E30 single pole one... not difficult at all with the engine in,just needs a deep socket and a universal joint.
Youth is wasted on the young.
daniele30
brown sender from E30, how about e36 ? which sender should we remove ?
some say black, some say blue . which one mate ?
- **BANNED**
Read the thread....blue is ECU,all my gauge senders,(3 E30's!) are brown!
Blue = ECUdaniele30 wrote:brown sender from E30, how about e36 ? which sender should we remove ?
Black on the E36 is removed and replaced with brown sensor from E30
daniele30
Thanks alot Beemerlad !E30BeemerLad wrote:Blue = ECUdaniele30 wrote:brown sender from E30, how about e36 ? which sender should we remove ?
daniele30
today i;ve replacced the m50 black sender with m20 brown sender.
its seems my temperature gauge still not works.
i notice m50 temp sender is 2 pin, m20 temp sender is only 1 pin.
Which M50 loom wire have you connected to the temp. gauge wire of the E30 body loom at the C101 connector.
The M20 connector earths through its metal body, rather than the second pin.
daniele30
I'm using 94' 525i M50B25TU Maroon label 413 ECU without EWS.
E34 engine wiring loom - Pin 12 (brown/violet) -> E30 body - Pin 4 (Brown/violet)
12 to 4 is correct, so if you have fitted a M20 brown sensor in place of the M50 one, your temp gauge should be fully functional.
If it isn't, use a piece of wire to short the brown/purple to earth at the C101, and see if the gauge goes to full hot with the ignition on.
daniele30
yes i've tried shorting the pin 4 to the ground.
my temperature gauge goes to Maximum...
in this case would be my temperature sender is faulty ??
Now short the brown/purple wire at the temp sensor plug to earth, and see if that does the same thing.
If it does, the sensor is faulty, or the wrong type. It must be a single pin E30 one.
daniele30
my brown sender is taken off my 1992 m20 325i . its a single pin sendor.
anyway i will try to get another to try it out.
thanks alot mate
thanks alot mate
