removing wheel nuts 528
toecutter666
My uncle just phoned to say he's got to take his wheels off his 528 but the locking wheel nuts have got internal splines and he never got the key when he bought the car a couple of weeks ago. any ideas how to get these off without the key.
E30Gheko
Should there be a plug type key to go into them?
bodger
large multipoint socket knocked over the head if possible or large torx socket/allen socket hammered inside
- E30 Zone Meets/Events Team
There are a different array of splines to these.
Will either find it in the rear boot toolbox or glovebox.
If not, then there difficult to take off, unless someone close to you has got some.
E30Gheko
Best thing to do would be to get some replacement bolts first, then head down to your local friendly tyre centre. They should be able to get them off for you. I've had them off with the socket technique above but it depends what type of key it is.
toecutter666
Cheers guys, he's looked all over the car but no luck, i'll have to tell him to go the way of the gheko and get some replacements before heading down the tyre place.
Dont go to the tyre place, if its got the genuine BMW bolts you can buy replacement tools for them
But only if you know the code. Which is stamped into the end of the bolt (thread end). Which means you need to get one out first.DanThe wrote:Dont go to the tyre place, if its got the genuine BMW bolts you can buy replacement tools for them
toecutter666
Ah the dreaded catch 22, will see him later so might take my impact sockets and a lump hammer and see what damage i can do
boybimmerm3
Just go to a BMW dealership and they should have a master set and will then order you the correct one or might even sell you their one and they will just order themselves another.No need to start hammering
Bob_S
+1 been here before with locking nuts.boybimmerm3 wrote:Just go to a BMW dealership and they should have a master set and will then order you the correct one or might even sell you their one and they will just order themselves another.No need to start hammering
Bollocks to this 24v scrap!
fingerman
A Gator Grip Universal Socket should do the trick
Previously owned loads of old E30s, E34s, a few E36s, E32s, E39s and an E38.
Currently in a diesel Audi - miss me old E30's....
oze30
Toecutter,
Is it the bolt that has an internal spline or the key? If it's the bolt, see spadge. There's various sets floating round, one will fit!
toecutter666
its the bolt that has the internal splines oz, i'll give spadge a shout if my uncle hasn't sorted it, cheers
- **BANNED**
IF the bolts are the original one's,giving a stealer the VIN number may turn up the code for the bolts...
Youth is wasted on the young.
bodger
you lot would be no good as criminals would you
get that lump hammer out
