Lee Parkes' E30 Alpina B10.
DRIFTBOY
Post Tue May 12, 2009 1:15 am
Good work dude!
I bashed my bulkhead in, and I think it's a useful thing to do for engine position three, and it doesn't cost anything! :D
I'm sure my 325i gear linkage went on the same side as the M30 one...?
I can't see it making a difference, not 100% sure though.
Post Tue May 12, 2009 9:28 am
I think I put it in the same way as the m20 box iirc.
But if it isn't, it's easy enough to do anyway.
Lee, the box will come out easy, loosten the engine mounts, do NOT TAKE OFF THE NUT!! and tilt the engine and there snough clearence in the tunnel for the box to slide out.Did it twice on mine when the flywheeel has to come back out.So don't worry too much mate
Post Tue May 12, 2009 11:20 am
Good work done, not much more to do now :)
Are you keeping the 2.5 exhaust or getting a custom one made?
leeparkes
Post Thu May 14, 2009 10:32 pm
ITS IN!!!
Well its in but not plumbed in,
i aint touched it for a couple of days and today it was a spur of the moment decision to get it in the bay,took me an hour an half and the only nightmare i had was getting it on the mounts but with a little help off the wife (she was controlling the hoist 8O ) it went on no bother,ive got it in position 3 and with plenty room behind the baulkhead (well about an inch,lol)
First job to do now is reconnect the prop,gear linkage,etc..then get the down pipes on and see where i stand with the exhaust,(imy) for now ill be mating the 325i system up to it to get it on the road but in the near future ill be getting a 50mm twin pipe custom system made up.
im in two minds what to do about the rad as all ive got to use is my M20 one because the E34 one dont fit :?
If the weather isnt too bad tomorrow it might be fired up,(without down pipes of course :evil: )
Post Thu May 14, 2009 10:40 pm
Sexual man, looks awesome :cool: :cool: :cool:
I'm pretty sure Rav is using the E34 rad, is it too big?
winx
Post Thu May 14, 2009 10:41 pm
looking good fella, lurvely job of the engine you have made!
leeparkes
Post Thu May 14, 2009 10:46 pm
ImysE30 wrote:I'm pretty sure Rav is using the E34 rad, is it too big?
Theres two types of E34 rad and ive got the wrong one :(
Post Thu May 14, 2009 10:52 pm
I've read that the E28 rad is a good one to use :)
Have you tried the scrappy's for the right E34 one?
Post Fri May 15, 2009 12:21 am
lee looking good, but i can see one problem,
that is the elec fan mate, it should have gone in b4 the engine as its going to be awkward to get it in and do the mounts for it.
There isn't alot of room for hands to get in and drills so the mounts can be fixed.
Sorry mate if i put a dampner on it but i found that when i did mine, :cool:
leeparkes
Post Fri May 15, 2009 12:33 am
Rav335uk wrote:lee looking good, but i can see one problem,
No panic rav! i fitted the fan before the engine went in,drilled,mounted and tested
Then took it out whilst the engine was being put in :wink:
Post Fri May 15, 2009 12:35 am
HaHa, good man.
Observant ain't i though. winkeye
DRIFTBOY
Post Fri May 15, 2009 2:04 am
Looking good Lee, nearly there! 8)
What diff ratio are you going to be running this with?
leeparkes
Post Fri May 15, 2009 8:58 pm
DRIFTBOY wrote:What diff ratio are you going to be running this with?
Theres a 3.64 open diff on at the mo so ill see how i go with that,i want a slipper but not sure what ratio to go for.
Post Fri May 15, 2009 9:33 pm
It'll be a bit quicker than mine with that diff. winkeye
leeparkes
Post Fri May 15, 2009 10:03 pm
ITS ALIVE!!!! :rock:
Started underneath and connected the 325i prop up (perfect length) and sorted all the gear linkage business out,got the down pipes on to see how im going to mate it up to the exhaust and the curve of the pipes seem to match the E30 floor pan,took them back off and started up top with the heater hoses.
The hose that goes to the bottom stub went on with no fuss after being cut to size,the top stub hose on the other hand ive had to make a hybrid hose with the E34 front half and E30 rear half,the top stud sticks up at an angle and couldnt get the original hose on without it kinking.
Here's the hose i knocked up!
And both hoses on,i might try and re-route the top hose though
Then fitted new fuel hoses,the others were a bit :?
After this i was on a roll and sorted the loom out
coil is on the clutch fluid mount using an E30 strap,and the earth leads reach perfect on the suspension turret.
I put the relays into an E30 cover and they wedged nicely up where the the loom goes through the baulkhead
connected the ECU up and secured under the dash after rotating it 180 dgrees,connected the main live up and after this i didnt realise i could test it,
so i couldnt resist!
after a couple of turns it fired,without downpipes of course,
What a feeling :D
I thought M20's were loud but my god this thing shook the floor! all the kids in the street ran off screaming,lol
Only let it run for about 5 seconds (twice winkeye )
After this i test fitted the M20 rad and here's the clearance
Got to work out the top hose though :roll:
Im a VERY happy boy though! :D :D :D
leeparkes
Post Fri May 15, 2009 10:05 pm
Rav335uk wrote:It'll be a bit quicker than mine with that diff. winkeye
I know :wink:
Post Fri May 15, 2009 10:06 pm
That is close 8O
Where's the vid of the start up?
Post Fri May 15, 2009 10:47 pm
DO NOT CUT THAT HOSE!!!!!!!!!!!!!!!!
You'll need it for when you put in the e28 or e34 rad, and that hose is not easily found.
The heater hose is exactly what i've done too!
Looking good, and I bet it was ~LOUD~ too.
I remember mine too.
That rad's spacing with the dizzy cap is the same as mine, tighter than a virgins p###y winkeye
Post Fri May 15, 2009 10:55 pm
Rav you perv tut tut :P
So is a 3.64 diff better than a 3.46 diff? :?
leeparkes
Post Fri May 15, 2009 11:14 pm
Rav335uk wrote:DO NOT CUT THAT HOSE!!!!!!!!!!!!!!!!
I know mate,
ive got a load of old hoses up the shed including top hoses,but im thinking of the easiest way to join the two together,some sort of S bend i think.
Might just save the stress and get an E28 rad from GSF
leeparkes
Post Fri May 15, 2009 11:16 pm
ImysE30 wrote:So is a 3.64 diff better than a 3.46 diff? :?
Better for acceleration winkeye
Post Fri May 15, 2009 11:17 pm
I know mate,
Cant be that expensive? New rads are also much more efficient 8)
Post Fri May 15, 2009 11:19 pm
Get the rad and stops pis5ing about later mate.
Imy Lees diff will be quicker to 60, but mine is a better cruiser on the motorway.
Swings and roundabouts really and depends on what you want the car for.Mine is alot of travelling up and down the A45 to Cov and back so does me.
Lee, when urs is running, want a quick trip in her to see what diff the diff makes
leeparkes
Post Fri May 15, 2009 11:20 pm
Is this how your top stub hose sits (over the servo)
Post Fri May 15, 2009 11:24 pm
Yep, goes from the front, underneath the inlet manifold bracket, and then out and over the servo and into the heater matrix. :cool:
gareth
Post Fri May 15, 2009 11:30 pm
leeparkes wrote:after a couple of turns it fired,without downpipes of course,
What a feeling :D
I thought M20's were loud but my god this thing shook the floor! all the kids in the street run off screaming,lol
ahaa, the obligitory exhaust-less M30 first fire up! I think we all did that! sound rather like a spitfire don't they! (or should that be a ME109?)
oh, you'll need to cut that top rad hose a bit whatever rad you use. it'll need to stretch a fair bit to get onto the radiator stub so if like me you're unlucky, the old hose will split after a while. if you leave it a bit longer than necessary, you'll at least get to cut it shorter and re-clamp for a bit if it does split.
they're about £45/50 new iirc so no huge drama
leeparkes
Post Fri May 15, 2009 11:32 pm
Look what ive done to the freshly painted inlet mani :( not even sure how ive done it,could be the off the jubilee clip on the top hose
Hopefully the top hose will cover it
Post Fri May 15, 2009 11:43 pm
I did the same to mine, but i didn't tell anyone, but boy was i annoyed. :evil:
Hose should cover it. :D
gareth
Post Fri May 15, 2009 11:45 pm
i managed to spray coolant all over my freshly painted rocker cover.. loose bleed screw :o:
it left a matt finish watermark that won't clean off :? oh well, it's better than 2mm of flaking crusty aluminium oxide! :D
Post Fri May 15, 2009 11:53 pm
:snigger:
leeparkes
Post Sat May 16, 2009 12:02 am
gareth wrote:oh well, it's better than 2mm of flaking crusty aluminium oxide! :D
:nono:
i hit the back of the rocker cover too when it was going in :banghead: cant see it though as the loom covers it :D
Note to self: buy some bubble wrap next time i drop a freshly painted lump in a car.
Post Sat May 16, 2009 12:08 am
Good idea ,man :cool:
gareth
when i had the head off recently, i decided to clean up and paint the manifold and rocker cover, took like 3 years to get round to that!
when i refitted it all, i left the spare crusty rocker cover on to save scratching it while tinkering, makes it more annoying that i did mess it up within a week :? ho hum.
Post Sat May 16, 2009 11:12 pm
What;s happened.
Has it gone on the road yet??? :mad:
leeparkes
Post Sun May 17, 2009 12:04 am
Rav335uk wrote:What;s happened.
weather has been a bit rough round here today,flash floods,even had hail 8O
Managed to source an E34 rad though,but the flush test was'nt very good,filled it with hot water then felt around it and the bottom was cold (about 4 inch up) and the top was hot so its blocked at the bottom :(
the m20 rad actually holds more water,you can see the size difference in the pictures
been trying to flush it clean but its not having it,any tips? like is there something i can leave in it over night then flush in the morning,like drain buster but for rads lol
left it like that for about 2 hours :banghead:
jobs left to do
Radiator
Exhaust
Tidy it up
Then test drive
P.S. my laptops playing up so may be a bit slow on responses
