if anyones wondered about using vinegar...
choppa7
Post Tue Aug 07, 2007 8:35 am
it seems to do the trick nicely!!
I got some calipers off Theo ages ago and on Friday night swung via Morrisons on the way home and picked up 5L of malt Vinegar for £2.20.
I put a bin bag into a bucket as a liner then seperated the cal;ipers and left them to steep over the weekend, I got them out on Sunday night and gave them a wire brushing and a scrub then put them back for another night.
I got them out again last night and after some more wire brushing and a good bit of elbow grease with a normal rough scrubbing brush, the calipers seemed to look a bit better
The light brown "Fresh" rust looking areas are where the metal was exposed so I think thats oxodising and will rub down ok, I could be wrong though. Either way I'm happy and they should look fairly decent with a coat of paint. 8)
1990 318i Lux
mattyb240
Post Tue Aug 07, 2007 1:43 pm
Never heard of that! But fair dues, bench grinder all the way i'm afraid can't stand the smell of day old vinegar!
geo1400
Post Sat Aug 11, 2007 10:41 am
What about using coke? (as in coka cola... 8O )
Everyone knows about the penny trick? I've used it on golf clubs before and it works a treat!!
Geo
Post Sat Aug 11, 2007 10:52 am
Sodium carbonate solution (I think), a sacrificial anode (lump of iron) and a power supply. Check out the kit car forums.
smithy318i
Post Sat Aug 11, 2007 10:57 am
geo1400 wrote:What about using coke? (as in coka cola... 8O )
Geo
Yes you can use cola and it would be better.
Cola contains both phosphoric and citric acid, and both are stronger than acetic acid (vineger)
geo1400
Post Sat Aug 11, 2007 11:08 am
Geo
Well there you go then, get those callipers in some cola!!
sam325is
Post Sun Aug 12, 2007 9:05 pm
I used bench wire grinder, no dirt or rust or anything stood a chance. They were back to bare metal in no time. Then for the tricky gaps i used a very stiff rotary brush in a drill. Then rubbed them down with some strong degreaser and bingo color them.
choppa7
Post Sun Aug 12, 2007 9:47 pm
geo1400 wrote:
Geo
got a bit of time before they go on thar car so I might ge the coke out to finish them off,
Brian me and liquid and a power source aint a good idea :mad:
1990 318i Lux
DavieP
Post Thu May 07, 2009 5:37 pm
geo1400 wrote:
Geo
Well I 'swung by' Somerfield on my way home and bought 2.5 gallons of Cola for the princely sum of just £1.08 (9p per litre). So now discs and callipers are fizzing & popping away. Be interesting to see the results by the weekend.
Dave in Torquay
Banjo1981
Post Thu May 07, 2009 5:47 pm
I hope it was diet cola!
paulmitchell1984
Post Tue May 12, 2009 12:40 am
would this work on other parts aswell, or is it just hard cast metals, im thinking lower arms nuts botls etc...
bobbin1982
Post Tue May 12, 2009 9:43 pm
personally i would try and ssubmerge my metals into paint stripper or something :mad:
Driving my digger!!!!
feens
Post Wed May 13, 2009 2:47 pm
Brianmoooore wrote:Sodium carbonate solution (I think), a sacrificial anode (lump of iron) and a power supply. Check out the kit car forums.
What way is the battery connected across this Brian i hear its the best way to remove rust, (i want to do my toolkit) one terminal on the Anode and where does the other one go??
S50B30 E30
Post Wed May 13, 2009 9:17 pm
feens wrote:What way is the battery connected across this Brian i hear its the best way to remove rust, (i want to do my toolkit) one terminal on the Anode and where does the other one go??
I can't remember, but the lump of scrap iron is a sacrificial ANODE, so probably the positive wire goes to this and the negative to whatever you're derusting.
feens
Post Wed May 13, 2009 9:50 pm
So -ve to the spanner for instance?? would it not short in the solution????
S50B30 E30
Cotty
Hartge Crew
Post Wed May 13, 2009 10:13 pm
So does that work in reverse of one of these kits used to plate things?
http://www.frost.co.uk/item_Detail.asp? ... ostSubcat=
mattyb
Post Mon Jun 01, 2009 6:38 pm
for removing rust i strongly recomend this i im using for my suspension as i am rebuilding it,
its exellent stuff but not cheap.
http://www.bilthamber.com/deoxc.html
A1BMW325iSport
Post Mon Jun 01, 2009 8:16 pm
mattyb wrote:for removing rust i strongly recomend this i im using for my suspension as i am rebuilding it,
nice one i'll have to get some of that :D
Rodderz
Post Mon Jun 01, 2009 8:24 pm
Brianmoooore wrote:Check out the kit car forums.
NEEEEVVVVVVEEEERRRRR!!!!!!!!!!! :D
