iv just started my m30 conversion today....
to me looking from underneath the engine (with a two poster ramp)it will be easy to drop the engine out from the bottom(with the box and subframe still attached) with the aid af few trolley jacks!!.. rather then lifting out....and hopefully putting the m30 engine the same way....
few quick questions if can be anwser asap
1.. how deos the engine wiring come out/can it be left on when dropping the engine out or will it need be removed separtely.
2...im not sure what rad im gonna go with yet... is it possible to put the rad in after m30 engine is in or advisable to put it in before the engine goes in pending on wat rad im going with.(engine will be in postion 3)
3... 4 speed box from a 633ci or 5 speed from e28 528?/ which is better
4...the gear shifter is it easy to change when the engine and box is in.
5...and do i have to remove the the covers(i think its sound proofing or heat proof covers) on the bulk head
thanks
