citizensnips wrote:having trouble with my brakes as i cant get the left hand drive 540 master here, wondering if i can use master with no servo
Yes you could but i see no sense in that kind of setup unless you're building strictly race car.
is your ecu going to live under the dash or in a box i engine bay like the 540?
whats the stuff in the battery tray? abs?
ABS pump, siren for alarm, power distribution box.
I built a place for ECU and relays on the original mounting location, the wires are really close being long enough.
anyway i digress, which fuel pump are you using?
looking very good by the way,
I bought Walbro fuel pump, good enough to +500hp so i guess it'll be enough for this setup
Friend of mine is using original in-tank fuel pump in his E30 V8 so that's one option too but my fuel pump was in such a bad condition that i decided to replace it with something more powerful.
