Rocker Cover Ideas
Dan318-is
Post Thu Jul 28, 2005 6:42 pm
low its only guna b the BMW but tho
its not guna b for ages its not defo just an idea tho
Post Thu Jul 28, 2005 6:46 pm
yeah i know its just the letters.. wont look good imo
Dominitry
Post Thu Jul 28, 2005 6:56 pm
318-is wrote:im doing mine the same as above except the bmw logo ig going to be colour coded to match the mtec logo eg the B will be light blue the M will be dark blue and the W will be red
wat du think?
Is this what you mean?
Minus the stripes being blue.
Dan318-is
Post Thu Jul 28, 2005 7:05 pm
precisly that
looks ok i guess not as good is i thought
i do like that black n silver one tho
is that ur motor pal?
Dominitry
Post Thu Jul 28, 2005 7:07 pm
318-is wrote:precisly that
The engine above is not mine no, the black rocker cover is mine though, tech 1 sport.
Dan318-is
Post Thu Jul 28, 2005 7:08 pm
hm maybe il just stick to the silver idea like the rest of u's
nice strut brake and clean engine bay in that e30 tho
cabrio327i
Post Thu Jul 28, 2005 8:26 pm
Wrinkle paint black, Car Builder solutions,Redlands,Lindridge Lane, Staplehurst, Kent, TN12 0JJ, Code PNWRB Total Ԛ£11.75 Tel- 01580 891309 Cheers Dave
jonmsm
Post Thu Jul 28, 2005 8:44 pm
This sounds interesting as I salvaged the rocker cover from my 1602 to make into a decoration for my wall (true bmw nut style having parts on the wall).
So, from reading this, I gather the best way is to first:
clean the thing down good and proper with some carb cleaner or brake cleaner
then a coat of etch primer I saw someone mention??
next a top coat of the wrinkle paint or dimple paint as the previous post recommends
remove the paint from the tops of the bits you want to polish before the paint sets hard
then polish off the lines and the BMW badge with something abbrasive like t-cut or autosol?
let me know if that sounds about right and I think I might soon have me a nice pretty new wall decoration.
1986 e28 M535i (gone and missed)
1988 e30 320i cab (full resto STILL in progress)
1996 Volvo 850 T-5 estate (280bhp Turbo Nutter), T-5R (my precious)
1966 Fiat 850 saloon & 1970 Sport Coupe
C1 (go-kart)
shane320i
Post Thu Jul 28, 2005 11:51 pm
this is mine,bit different to the norm but i like it :)
Demlotcrew
Post Thu Jul 28, 2005 11:55 pm
Heres mines;
A
Dan318-is
Post Thu Jul 28, 2005 11:58 pm
fook me i like it pal
luckily mines black :drool: so i can still do it silver like the above guys
Dominitry
Post Fri Jul 29, 2005 3:02 am
What strut bars are they, look like ac ones.
Templ8e30
Post Fri Jul 29, 2005 9:09 am
I used normal satin black spray then took the rocker cover and inlet manifold to work and skimmed the tops on the milling machine to get a nice even factory finish on the stripes and letters.
No need for high temp paint, the rocker cover doesn't get that hot ! and it's not peeling or bubbling after 6 months hard use.
See my sig pic for the end result.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Dan318-is
Post Fri Jul 29, 2005 10:25 am
dose anyone paint there inlet manifolds
Dominitry
Post Fri Jul 29, 2005 10:52 am
318-is wrote:dose anyone paint there inlet manifolds
Mines done to match the rocker cover, black with the silver.
Again done by Richy325iTouring.
Stevin
Post Fri Jul 29, 2005 11:39 am
Not very clean, and in that picture it makes it look like its really dull... but I wanted to be different... when I pull the engine again, I'm going to re paint it the same colour, but with a black intake manifold, block and head... nice to change things up.
BTW, there a 333i Turbo over here, thats whole engine is painted red... actually looks pretty hot.
Dan318-is
Post Fri Jul 29, 2005 11:57 am
some of these are bloody good guys
i take it you use the same painting technique for the manifold?
