My PBMW build....
SteMarsden
Post Sun Jan 18, 2009 8:34 pm
A few of you will know that Im building a PBMWC and just wanted to post a few pics of the progress so far.....
Collecting the car from Wayne Orr in Preston last August. My Dad actually working :0)
Really good strong shell
December 27th ready to start work.....
SPARCO cage
First trial fit, and looked pretty good...
Dash out. Was really expecting to have to do this but was not a great deal of work.
SPARCO floor plates welded in
Steel sheet ready for blanking sunroof (thanks Dad!)
Bonnet being drilled for bonnet pins
Sunroof panel in place and in primer
Foot plates sprayed and FX mount trial-fitted
My dad painting the roof while I sat about drinking tea! :o
Sharing workshop space with one of my Dad's 1966 Cooper 'S'
Cage fully painted
Pulls mounted for FX and lec-cut outs....
Rear arches repaired and painted
Delivery from GAZ :cool:
Standard 1.6 suspension and brakes.... URGH!
Cage in and painted
Oulton Park at BMWCC Trackday on Feb 13th...
Well earned rest
Repairing the fractured exhaust downpipe, er, I blamed the kerbs!
Pit garage, probably still smells of sick after Bob-S 'hot laps' ;0)
Championship decals on
Dash
CF door trims
More to pics follow...
BMW E30 318i ex PBMWC track car
2011 VW Passat Est
rix313
Post Sun Jan 18, 2009 10:41 pm
Looks good :) Some high res pics would be nice ;)
What engine does it have?
juniorGT
Post Mon Jan 19, 2009 1:00 am
nice progress budddy!
am i right in saying the 1st round @ brands is on the 15th of march? if so i will pop up and spectate
JD
318is.
Brian28
Post Sat Jan 24, 2009 6:25 pm
Looking good Ste, further forward than mine is and I've supposedly been building it since June :roll:
For sale - E30 320i racer project - sold.
Lloydie38
Post Sun Jan 25, 2009 11:08 am
Loving it, keep the progress coming and the spec would be good for a skeet (Manx for look btw :) )
SteMarsden
Post Mon Jan 26, 2009 8:44 am
Will take some more pics tonight and post up....
Cage is now painted and fitted, going to bolt up with 8.8 bolts tonight
Sunroof closure panel is also fitted and painted in brilliantrot
Dash and instrument cluster is back in
Bonnet pins fitted
Wheels being repainted in anthracite :cool:
Need to do before BMWCC GB trackday at Oulton Park on Friday 13th Feb (apart from the above)!
Connect up FX and FIA switch
Seal up burnt underseal after fitting cage
Paint arches underneath
Fit and set up/cornerweight GAZ suspension
Fit polybushes
Fit braided hoses and new pads/discs
...er, so not then before the 13th! :?
Spec will be full PBMWC spec (when it races, NOT for the 13th!)
More pics to follow....
Oh, and it will still have the M40 1.6 for the trackday.... :x
2011 VW Passat Est
Cloud
Mmmmmm Donuts!
Post Mon Jan 26, 2009 6:46 pm
Proper job!
I look forward too seeing pics of it on the track.
SteMarsden
Post Wed Jan 28, 2009 1:14 pm
Thanks all, high res pics now up.... will download some pics this week! :D
2011 VW Passat Est
Black_Potato
Post Mon Feb 02, 2009 8:44 am
Looking good :up
SteMarsden
Post Sat Mar 21, 2009 9:52 am
Now updated!
2011 VW Passat Est
red05
Post Sat Mar 21, 2009 4:50 pm
Top job :cool:
Looks like you'll be having fun come Summer :cool: :cool:
MrBenn
Post Sat Mar 21, 2009 9:04 pm
Looking good :D Good luck in your races :cool:
JimmyC
Post Mon Mar 23, 2009 10:12 am
Looking good Ste, sure your already aware but thought i'd point out before you turn up to race:
The seat in there doesn't meet PBMWC regs
SteMarsden
Post Mon Mar 23, 2009 12:34 pm
Thanks for the comments everyone, I'm just itching get out in it again!
Thanks Jimmy,
I have ordered a Cobra 'eared seat' through the drivers deals, just have not got around to fitting it thats all!
BTW. I have used the FIA seat belt mounting brackets in the rear bulkhead.
Do you think/know whether I need any other re-inforcement or are the FIA brackets (2 of) ok on their own?
Ta,
Ste.
2011 VW Passat Est
Bob_S
Post Mon Mar 23, 2009 6:12 pm
looking good Ste! It certainly went well at oulton despite being so wet! :)
Hopefully get out and catch some action from the pbmwc this year :)
Bollocks to this 24v scrap!
LeonNewton
Post Mon Mar 23, 2009 8:29 pm
looks cool man. let me know wen you wont help :wink:
Yer i am sorry for my bad spelling. i am dislexic and find it just as hard to read your posts as you do mine.
rix313
Post Mon Mar 23, 2009 11:30 pm
Look forward to seeing it at the rounds at combe
SteMarsden
Post Fri Mar 27, 2009 8:47 pm
New Cobra seat and 6 point harness fitted today....
2011 VW Passat Est
LeonNewton
Post Fri Mar 27, 2009 9:05 pm
looking sweet. carnt wate to see in the flesh/tin
Brian28
Post Sat Mar 28, 2009 7:36 am
Ta,
Ste.
Hi Ste, flat steel bar running behind the bulkhead, drill it to match the holes for the mounting points on the bulkhead. Min you will get away with is about an 8" piece to cover the two mounting points, better if you bend a long bit to run across the full width as it then picks up the stronger uprights. If you use long bolts initially, it pulls into the shape you want it quite easily and the scroots will be happier.
Brian
SteMarsden
Post Sun Mar 29, 2009 3:18 pm
Thanks Brian,
Cheap and easy. Exactly what I like! ;0)
Last thing I need is to turn up at first meeting and cant race!
:mad:
Ste.
2011 VW Passat Est
rix313
Post Sun Mar 29, 2009 8:56 pm
Don't have a template or anything for your carbon radio insert do you?
SteMarsden
Post Sun Mar 29, 2009 9:46 pm
I bought it off a zoner on here....
Its just a blank piece of cf that I have epoxied (sp?) into position thats all, I can measure the dimensions if you wanted.
Just PM me.... :)
Ste.
2011 VW Passat Est
rix313
Post Sun Mar 29, 2009 11:11 pm
Thats cool I'll get off me arse and measure mine :D
Really like this car, like I said, can't wait to see it :)
bramley
Post Tue Mar 31, 2009 6:27 pm
Ste, looking good. Would you (or someone else with the same setup) be able to post some more detailed pics of the harness mounts please? Pretty please lol! Not happy with my low down mountings for the harnesses, would rather they were done properly.
Cotty
Hartge Crew
Post Tue Mar 31, 2009 8:28 pm
Looks like a fun project :D
SteMarsden
Post Wed Apr 01, 2009 9:28 pm
bramley,
Belt pics for you.
Rear mounts
Rear mounts from boot, need to be strengthened to get through scrutineering as per Brians comments
TX tunnel mount (using FIA plate)
Underseat mounts (just visible)
HTH.
Ste.
2011 VW Passat Est
Black_Potato
Post Thu Apr 02, 2009 12:03 am
Hmmm... You wont want to hear this but those lap belt fixing points look to far forward to me as well.
Have a look in the blue book, the belt needs to come up from behind at a given angle which I'm not sure you have there.
crossie
Post Tue Apr 07, 2009 2:35 pm
What have the scrutineers said about your cage being for a left hand drive car not right?
If nothening maybe worth getting another bar welded in.
Brian28
Post Tue Apr 07, 2009 5:25 pm
There is a welded in diagonal from the drivers head side of the hoop to the passenger side rear as per normal 6 point cages so would pass Ok with this, the bolt in diagonal and cross bar is just an added extra to what is necessary to pass scrutineering. PBMW (but not MSA) regs originally specced an extra diagonal or cross brace for 6 point cages, but this requirement was dropped last year.
Jamese30
Post Fri Apr 10, 2009 10:27 pm
Loving the pics mate.....keep up the good work.
Jimmy
James
BMW E30 327i
Mini Cooper S
SteMarsden
Post Sat Apr 11, 2009 11:44 am
Brian28,
Managed to get hold of some 6mm x 40mm steel for the rear seatbelts re-inforcements so I'll let you know how I get on over the B.Holiday!
Black_Potato,
Just checked the BBook and they should be 65 deg so will check later, thanks. BTW, Im not out at Donington so could you bring my discs to Oulton Park in August if you dont mind holding on to them? Ta.
Jamese30,
Thanks for comments, its been a while since you have seen her in the flesh! You need to start posting some pics of yours :D
2011 VW Passat Est
SteMarsden
Post Sun Apr 19, 2009 11:42 am
Well, it was a lovely day yesterday and I got to spend some proper time on the car in the sun!(albeit mostly underneath!)
Now I know that this is a racecar and wont spend much of its time on salty winter roads, but coming from a background of mini's and seeing some of the pics on here, I decided that a bit of 'preventative' work would'nt go amiss before I'm left with an expensive lump of iron oxide!
The offending item
Finally! Thanks Bob-S!
Beam which has been primed and painted satin black, with new Powerflex bushes.
With 4.1 open diff bolted up
Painting started (what a bl00dy thankless task!)
Catching the creeping brown stuff!
One brake line had aleady been replaced (badly) with copper, the other original steel pipes were badly corroded.
Making up replacement pipes....
More to follow later....
2011 VW Passat Est
Jamese30
Post Tue Apr 21, 2009 10:23 pm
I like it Ste, I like it...
Looks great mate. Interesting that those powerflex trailing arm bushes are two piece items. The superflex ones I bought the other day ar single piece??!
Will try and get some pics of mine posted this weekend after a good days work on it on Saturday.... winkeye
James
BMW E30 327i
Mini Cooper S
Bob_S
Post Wed Apr 22, 2009 12:36 am
good work ste! no worries, glad i could help
