M20 engine mount options
Dan320is
I'm replacing the engine and gearbox mounts on my touring and I was wondering if there was a better designed engine mount that will fit from another BMW?
I've got e28 M5 engine mounts on my 318is as they are a better mount. I know about the hockey puck groupbuy but I'd rather stick with BMW supplied parts.
Anyone?
Anyone?
Ant
- Retired Team Member
poly mounts for a MK2 escort Dan
£6 each from Rallye design iirc
Email FTW
Dan320is
Ah, I was hoping you'd surface mate.Ant wrote:poly mounts for a MK2 escort Dan
You mean these? Can't find the exact poly mounts you mentioned.
http://www.rallydesign.co.uk/product_in ... s_id=13049
Dan320is
I can't seem to find the mounts mentioned by Ant but I've just come up with a solution.
I will update people when I have pics, just got to get some machining done.
BadDave
Those are the Vibra Technics mounts.Dan325iSport wrote: You mean these? Can't find the exact poly mounts you mentioned.
They make E30 ones as well,although RD don't seem to list them.
The £6 ones are Mk1/2 Escort H/D mounts.
There are 2 sizes, 35mm and 50mm.
It's teh 50mm ones you need.
Dan320is
I can see 50mm on there but they're not £6, they're £43.17.BadDave wrote:Those are the Vibra Technics mounts.Dan325iSport wrote: You mean these? Can't find the exact poly mounts you mentioned.
BadDave
Dan320is
Cheers Dave, I looked through the engine/gearbox & suspension mounts section and still couldn't find them.
BadDave
I had to look up the catologue to get the part number in order to find it on the website.Dan325iSport wrote:Cheers Dave, I looked through the engine/gearbox & suspension mounts section and still couldn't find them.It must be my turn to be thick today.
zaust
- Zone day release
Whats the height of a standard M20 mount?
town325i
ive used genuine mounts for the engine and gearbox and they didnt cost the earth, had no problems with them in the six months i had my car on the road
zaust
- Zone day release
If you want to lower the engine and up-rate the mount then get some landrover engine mounts, perfect for a track car, like having the engine sat on lumps of wood
Ziggy
Bump
I need to know how the 2 sizes (and indeed LR ones even!) compare to standard ones too...
50mm: http://www.rallydesign.co.uk/product_in ... ts_id=7219
35mm: http://www.rallydesign.co.uk/product_in ... ts_id=7218
zaust
- Zone day release
BadDave
Marc/Jon
I've just measured the ones holding up the M20 and they appear to be in the region of 40mm when compressed.
AFAIK they are std BMW mounts.
HTH
HTH
Ziggy
Cheers mate
Reckon I'll give the 35mm jobbies a go then.
Ziggy
Ordered the 35mm ones. I'll report back as to whether they fit/are any good!
stonesie
How did they turn out Ziggy?
Ziggy
Too short for an M30! Needed to space them up a bit to let the sump clear the steering rack. You really need to measure what you have currently, and the amount of clearance you have.
stonesie
Current mounts are around 40mm iirc (too late to double check now) so i ordered a pair of 50mm mounts
Ziggy
It says that about six posts up!
I went with the 35mm ones with the thought that I could easily space them by 5mm, and I didn't really want to end up with the engine 10mm higher.
Anyone tried the Landrover one's and know what size they are?
Will they fit and not cause a problem like Ziggy's above?
