Driftben
Post
Mon Mar 23, 2009 10:05 pm
i have picked up the M112 eaton charger and im going to be fabricating a adaptor to fit it to the back of the M30 inlet plenum, im just wondering if i could get a crank pulley to match the pulley on the charger. (or get one made)
iv worked out that it will need to be 1.7 times bigger than the charger pulley size.
just need to find out the distance from pulley to pulley so i can line them up and get the charger fitted.
long process.
thanks
ben
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
baptie0
Post
Mon Mar 23, 2009 10:24 pm
what size is the pulley on the engine that the charger came from?
Driftben
Post
Mon Mar 23, 2009 10:28 pm
the charger is a eaton M112 from a V12 jag.
im still yet to find a suitable pulley for the engine side. (abit of advice on that)
6pot wilwoods front
4pot Porsche rear
rix313
Post
Mon Mar 23, 2009 10:35 pm
On the Eaton M45's we've used a crank pully from an M43 and a spacer, not sure how compatable it is with your engine or charger though.
Driftben
Post
Mon Mar 23, 2009 10:40 pm
i was hoping to keep the flat belt type pulley instead of the `v` type. its got a real long reach on the charger which helps a lot but its a pain because i want to get on and get it fitted but i need to find a pulley to measure and line it up from, (from engine to charger)
im crap at explaining so im sorry for that, im doing my best.
6pot wilwoods front
4pot Porsche rear
baptie0
Post
Mon Mar 23, 2009 10:42 pm
what is the diameter of the pulley on the m112
punk_sy
Post
Tue Mar 24, 2009 12:43 pm
that chargers a beast
Driftben
Post
Tue Mar 24, 2009 1:12 pm
I'll have a measure of the pulley tonight.
The charger is just in place for a short while untill I get enough dough for a twin screw charger.
Really want the e30 on the road for this summer. Alot yet to do.
6pot wilwoods front
4pot Porsche rear
e21Jason
Post
Tue Mar 24, 2009 1:30 pm
Talk to nigel aka alloyproducts on here he has my m30 engine and is making some custom pulleys, so he could profably make the brakcets and pulleys to fit the charge in one go.
Jason
Turbo-Brown
- Boost Junkie
Post
Tue Mar 24, 2009 1:31 pm
Are you gonna fit a charge cooling panel between the 'charger and the manifold?
325i Twin Turbo (until 10am 01/12/07
www.air-in.co.uk free M20
exhaust and inlet flange
Driftben
Post
Tue Mar 24, 2009 6:57 pm
I'll do a search on here In sec and get hold of him, that will be underway then
As for the cooling panel I was thinking of making one out of diavic but I'm all ears for ideas.
I was hoping to do a complete post of the build but there is a few already and I'm still gathering pictures and info/help
Ben
6pot wilwoods front
4pot Porsche rear
Driftben
Post
Tue Mar 24, 2009 7:17 pm
Right the charger pulley is about 32mm.
To get the charger at the right speed for what I need I'll need a pulley 1.7 times bigger for the engine side of things. If that makes sense.
6pot wilwoods front
4pot Porsche rear
baptie0
Post
Tue Mar 24, 2009 7:29 pm
how much boost are you going to run the charger at?
Driftben
Post
Tue Mar 24, 2009 7:39 pm
I'm thinking of running around 1 bar but at this stage I'm not certain. Really as much as I can run. Power/ reliable type of thing.
Up for sugestions though.
6pot wilwoods front
4pot Porsche rear
baptie0
Post
Tue Mar 24, 2009 8:10 pm
i reckon a charge cooler is going to be first thing your going to need, and also some kind of engine management system.
richard-the-nutter
Post
Tue Mar 24, 2009 8:14 pm
i reckon you could find a suitable pulley off an aircon motor, maybe
Looking for an e30 in the north east!
Driftben
Post
Tue Mar 24, 2009 8:37 pm
Well I was going to use a megasquirt which I was going to pick up cheap.
As for the cooler I was going to use a large (or as big as I can) intercooler. I think the charge cooler route will be a right pain.
The pulley side of things I'm not sure if I'll be lucky enough to find the right size and width I'll have a good old look though.
I'll work out what size I'll be looking for.
6pot wilwoods front
4pot Porsche rear
baptie0
Post
Tue Mar 24, 2009 8:47 pm
where are you planning on mounting the charger?
Driftben
Post
Tue Mar 24, 2009 9:08 pm
straight on the back of the inlet plenum. nice bit of space there. well if its possible....
i picked up my head parts today
uprated rocker arms
larger valves
uprated double valve springs
so its slowly comming together
6pot wilwoods front
4pot Porsche rear
baptie0
Post
Tue Mar 24, 2009 9:35 pm
you wont be able to cool the charge with it mounted there. you could still mount it there but i think you should keep the boost a bit lower than 1 bar to keep the inlet air temps low. are you going to reduce the compression a bit.
Driftben
Post
Tue Mar 24, 2009 9:52 pm
ah very good point. back to the drawing board with that one then. possibly mount it lower and add more pipe work to the intercooler then to the manifold.
i have sent the head into the machine shop to check if it needs to be skimmed. hopefully not because i dont need to use such a large head gasket. but ya i want to lower the compression abit. still something i need to work out by how much.
6pot wilwoods front
4pot Porsche rear
DRIFTBOY
Post
Tue Mar 24, 2009 10:33 pm
Fantastic stuff, I'm liking this!
Could you please tell me who those rockers are from, they look very much like standard ones, higher lift..?
Driftben
Post
Tue Mar 24, 2009 10:47 pm
The rockers are from irland engineering. The rockers have a thicker body so won't snap in the usual place. I can run a high lift with these.
That company has lots and lots of stuff for m30.
Porn really.
6pot wilwoods front
4pot Porsche rear
DRIFTBOY
Post
Tue Mar 24, 2009 10:52 pm
Thanks!
I'll be following this one, good luck!
Driftben
Post
Tue Mar 24, 2009 10:56 pm
Thanks for that. I'll think I'll need it hehe. More pics to come.
6pot wilwoods front
4pot Porsche rear
Driftben
Post
Sun Apr 05, 2009 10:19 pm
alittle update...
head has been sent away to be port & polished and then built so while that been going on iv been cleaning the bottom end and trying to source a suitable head gasket.
only problem iv come across is trying to get the main nut off the end of the crank so i can change the timing chain and tensioner. i just cant keep the bugger from moving while i try the undo it. iv even tried adding beer to the pa-lava.
any ideas on this?
a couple of pics....
6pot wilwoods front
4pot Porsche rear
appletree
Post
Sun Apr 05, 2009 10:31 pm
I welded a bit of bar to a spare pully that bolts to the crank pully, then rested it on the floor and gave the nut/bolt some abuse from a 3/4 braker bar, did the trick.
Driftben
Post
Sun Apr 05, 2009 10:35 pm
good idea that one. i shall give it a go...
need to find some more pulleys that fit anyway because i have the powersteering one missing.
6pot wilwoods front
4pot Porsche rear
appletree
Post
Sun Apr 05, 2009 10:37 pm
O and if you do weld a bar across the pully, dont forget to weld the bar off centre so you can get the socket to the nut.
Not like the my first attempt
Driftben
Post
Sun Apr 05, 2009 10:40 pm
haha thank god you said that because i would off welded it centre
6pot wilwoods front
4pot Porsche rear
leeparkes
Post
Sun Apr 05, 2009 11:00 pm
Subscribed...
Post
Sun Apr 05, 2009 11:02 pm
project
Interesting to see which is easier, S/C or Turbo
Driftben
Post
Sun Apr 05, 2009 11:04 pm
well i was discussing the other day about twin charging?
shouldnt be too hard to do it, would it?
6pot wilwoods front
4pot Porsche rear
Driftben
Post
Sun Apr 05, 2009 11:10 pm
ImysE30 wrote:
project
im kinda of thinking its about the same difficulty for both
6pot wilwoods front
4pot Porsche rear
Post
Sun Apr 05, 2009 11:25 pm
STiBen wrote:ImysE30 wrote:
project
Would power figures be about the same as well?
