e38 alloys
reggiebaby
hi folks does anyone know if e38 alloys fit the e34 without the need for spacers
Pilsbury
The offset is correct, but, IIRC the center bore is different. Can't remember which way round it is, but, I think E38 is bigger, so, you'll need hub centric rings.
Ziggy
Yes they should fit. It's E39 that has the larger centre bore.
Offset'll be fine as above, but depending on tyre choice (& which e38 wheel you're going for), you might need a small spacer on the front. Worth noting that if they're coming straight from an E38 the tyres will be a bit on the large side...
reggiebaby
cheers these are the ones im looking at but in the description he said they foul on the shocks but thats on a touring.... http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... gory=10374
Pilsbury
I knew one of the E38 or E39 had a different center bore, couldn't remember which.
