e38 alloys
reggiebaby
Post Sun Mar 22, 2009 11:17 am
hi folks does anyone know if e38 alloys fit the e34 without the need for spacers
Pilsbury
Post Sun Mar 22, 2009 11:51 am
The offset is correct, but, IIRC the center bore is different. Can't remember which way round it is, but, I think E38 is bigger, so, you'll need hub centric rings.
Ziggy
Post Sun Mar 22, 2009 12:33 pm
Yes they should fit. It's E39 that has the larger centre bore.
Offset'll be fine as above, but depending on tyre choice (& which e38 wheel you're going for), you might need a small spacer on the front. Worth noting that if they're coming straight from an E38 the tyres will be a bit on the large side...
reggiebaby
Post Sun Mar 22, 2009 12:37 pm
cheers these are the ones im looking at but in the description he said they foul on the shocks but thats on a touring.... http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... gory=10374
Pilsbury
Post Sun Mar 22, 2009 12:40 pm
I knew one of the E38 or E39 had a different center bore, couldn't remember which.
