Who's turbo-ed an m50 ?
punk_sy
Post Wed Mar 18, 2009 6:08 pm
just thinking what you'll need to turbo the m50 and who has done it ?
Ive heard the non vanos is better for turboing is this due to difficulty's mapping the vanos with the turbo?
I'm asking because ill be looking at doing this to mine at the end of this year maybe if all goes well :) And a mate is in the process of turboing his car and hes not gonna beat me down the strip :twisted: for long.
GrindCulture
Post Wed Mar 18, 2009 6:10 pm
There's a guy on here with an M50 turbo touring, there's a thread somewhere in the photo gallary I think. Looks monstrous.
Not in E30s any more :(
punk_sy
Post Wed Mar 18, 2009 6:14 pm
oh yea sh1t remember that tried searching but i cant find much!
GrindCulture
Post Wed Mar 18, 2009 6:19 pm
punk_sy
Post Wed Mar 18, 2009 6:23 pm
haha yea thats a beast ut dont think ill be going that far with mine. well maybe one day :twisted:
baptie0
Post Wed Mar 18, 2009 6:32 pm
i am turbocharging my e30 m50, its a vanos engine but its not really a problem as the vanos is either on or off so can be switched easily by my ecu. i made a manifold using a m52 one mounted upside down.
punk_sy
Post Wed Mar 18, 2009 6:39 pm
baptie0 wrote:i am turbocharging my e30 m50, its a vanos engine but its not really a problem as the vanos is either on or off so can be switched easily by my ecu. i made a manifold using a m52 one mounted upside down.
what sort of mannagement are you using also would you need a wide band lamber sensor (i think thats wot it is?)?
baptie0
Post Wed Mar 18, 2009 9:24 pm
my ecu is a gotech v5, if you are going to map it yourself then yes you need a wideband lambda kit.
punk_sy
Post Thu Mar 19, 2009 6:52 pm
so ure using standard wiring just changed the ecu to a mappable one? also what do you mean map it myself you mean on the rollers ? have you just downloaded a map then ?
sorry for all the questions :mad:
baptie0
Post Thu Mar 19, 2009 7:41 pm
the ecu was supplied with a wiring loom and also a base map.
at the moment i am making a exhaust downpipe and system, when its finished, i can start mapping it on a quiet bit of road near where i live, i am going to use my wide band lambda kit to sort it out. then when the car is ready i will take it to a rolling road and have it set up properly. :)
tomson
Post Fri Mar 20, 2009 12:31 pm
BMw have, in diesel form :mad:
FormerMember
Post Fri Mar 20, 2009 8:59 pm
M50 is quite a nice engine to turbo. Friend of mine is building one at the moment.
Non-vanos is easier to go with.
www.pure-pf.com / forum / projekt is worth checking, lots of awesome e30 turbo projects going on in there :cool:
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
punk_sy
Post Sun Mar 22, 2009 4:30 pm
baptie0 wrote:the ecu was supplied with a wiring loom and also a base map.
are you doing a build thread soon ? :cool:
baptie0
Post Sun Mar 22, 2009 10:47 pm
yes i need to post some stuff up soon.
i am too busy fixing other peoples cars at the moment so i never seem to get much done :cry:
once i get the system finished i will get some pics up.
