M30 Rebuild - Fixing an unfinished project
Driftben
Post Tue Mar 17, 2009 9:02 pm
hi gents
nice to hear another M30E30 is on its way.
im currently in the same situation, abit ahead though.
im awaiting delivery of uprated rocker arms, valve springs, oversized valves and new valve stems with aload more from the states. they seem to be taking there time. just need to choose a suitable cam for a large supercharger and i can start rebuilding the head.
having trouble finding suitable breaks for the 318ti E36 setup but thats another story.
good luck with the progress, ill be awaiting pictures :D
ben
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
e30_singh
Post Tue Mar 17, 2009 9:45 pm
I tapped the shafts out today, just got the valve springs to remove now, will try and get this done tommorow so I can get this head ready to go for a test & skim. :roll:
e30_singh
Post Wed Mar 18, 2009 8:12 pm
Valve springs removed, head is going to the machine shop tommorow!
Cheers for the nudge Winx, your post made me get my finger out and get something done!!
e30_singh
Post Mon Mar 23, 2009 4:23 pm
another cracked head! :x
I think I may just scrap the M30 idea, keep on getting too many things going wrong! :?
winx
Post Mon Mar 23, 2009 4:27 pm
sorry to hear that fella. Got my engine out this weekend, head will be stripped tomorrow night I hope and bottom end the following day, then off for lightening/balancing etc.
You can't stop now, I need someone to encourage me to get my donk back in!
Maybe swap this for the other head Theo had?
e30_singh
Post Mon Mar 23, 2009 4:40 pm
My original head was cracked and so was the head I bought of Theo as well, thats the one I got to collect from the headshop. Will go there tommorow to discuss my options and whether it can be welded.
I May just pull the whole M30 setup out and replace it with a M50! I cannot take the heart ache no longer!!
Post Mon Mar 23, 2009 5:20 pm
Sorry to hear about your trouble's mate :( . Try not to give up now, it'll be worth the effort in the long run :)
If you do change, then at least do a M52 conversion :P :)
e30_singh
Post Tue Mar 24, 2009 10:47 am
This car is now breaking for parts.
If you need any of the following drop me a PM.
Brand new position 2 engine mounts
E30-M30 Loom
M30 gearbox
M30 ECU
There are loads of parts here for completing your M30 swap. Just bear in mind the engine has got no cyclinder head, I can supply some with but they have been pressure tested and they have all failed.
