You and me bothalso now have that picture on my desk top
Finally put new wheels on my car Deep dish Kerscher Carmona
greentouring
Wow!! They look great............ and they aren't even BBS!!
I reckon your 40/40 drop looks good, mate and is probably more pratical that mine. If i do another drop, it will be that.
blackcountrybimmerman
I'm liking the look of those mukka
It doesn't look like it does in my sig pic anymore
Thank's mate, you'll be seeing them in the flesh at the meetblackcountrybimmerman wrote:I'm liking the look of those mukka
Rav335uk wrote:Hope you've got big arms for polishing those rims
Thank's mate, you'll be seeing them in the flesh at the meet![]()
And you'll more than likely be seeing my bent and unpainted bbs's unless I get round to spraying them with a rattle can.....lol
I agree it does, i don't want to drop it 60mm as it's already too low on 40mm. Putting in a bigger/better/heavier engine might just do the jobraj1980 wrote:thats looking sweet. i know most might not agree but i think the front needs to come down more.
ImysE30 wrote:
I agree it does, i don't want to drop it 60mm as it's already too low on 40mm. Putting in a bigger/better/heavier engine might just do the job![]()
i need more power from my car too, what are you planning? i have been looking at a 325 conversion as its easy and cheap power. i need to get it looking right first.
Hopefully fitting a M52 (E36 328) engine in it after the summerraj1980 wrote:ImysE30 wrote:
Main problem/issue is the manifold, if you know a good welder then you'll be alright, otherwise expect to pay around £700 for a ready made one
It's more work and more expensive than fitting an M30 but is a more modern engine, with the same sort of power figures
- E30 Zone Meets/Events Team
- Contact:
Doesn't a stock M30B35 put out about 230bhp ? whereas a stock M52B28 is just under 200 ?
I know you can release extra horses on the M52 with manifold swaps etc but if you're going to feck around doing that you may as well do it on the larger capacity engine to start with
Cheers fella - still a good starting point in un-stressed standard formgooner1 wrote:No mate , think the stock M30 puts out between 211- 218 bhp.
220BHP standard but expect most to be around the 210BHP mark. Still undecided over M30 or M52capri_rob wrote:Cheers fella - still a good starting point in un-stressed standard formgooner1 wrote:No mate , think the stock M30 puts out between 211- 218 bhp.
GrindCulture
Well if you want something to weigh it down, M30 will do it, as M52s are lighter than M20s. Just put a few bricks behind the lights.
Not in E30s any more
Imy M30 it - you can get a 535i or a 735i donor car for next to nothing - you know it makes sense
looks nice. whats the offset/rim width/tyre profile? wouldnt mind a bit of stretch on my bus.
WMMotorsports
Rav335uk wrote:IMY, m30 it and be done![]()
Putting words in my mouthcapri_rob wrote:Imy M30 it - you can get a 535i or a 735i donor car for next to nothing - you know it makes sense![]()
ThanksDmcL wrote:looks nice. whats the offset/rim width/tyre profile? wouldnt mind a bit of stretch on my bus.
Front offset is 20 and back is 15 i think, could be the other way round
Front wheels are 7.5j wide and the rears are 9j wide
Got stretched tyres all round, 195/40/16 on the front and 205/40/16 on the back
