adjustable fuel pressure valve
LOOPYLEE1965
LOOPYLEE1965
Widge
I don't know
but then I don't see why you need an ajustable FPR
LOOPYLEE1965
Martinaston
If you didn't disconnect the ECU it should run the same as before. it has no sensors to tell it what pressure the fuel is at.
LOOPYLEE1965
johnono
the normal one is 2.5 bar, and the m3 one is 3.0 bar i heard. if i put an m3 one on would it do any good?
Dan318-is
not sure about the m3 one
iv heard these can cause fires
Lee is the performance of the car much better??
Martinaston
The 2.5 is from a 320 and the 3.0 is off a 325 or 318 all you do is overfuel the engine so you need to add a bigger throttle.
Dan318-is
ok
so assuming im already putting a big bore throttle body on my car, will one of these work well then? or cause fire?
im dum sorry
im dum sorry
johnono
cheers martin, u just save me a score
Martinaston
As long as you put it back together properly and the fuel lines are in good condition i can't see how you think it causes a fire ?
johnono
never heard of e30 engine fire
Dan318-is
i read another thread on these an a couple of guy said that they can cause fire or sumink hold on il find it
Dan318-is
Ladies and Gentlemen....
http://www.e30zone.co.uk/modules.php?na ... ic&t=13458
let me know what u lot think etc im not sure whether to get one or not.
johnono
if its an oem part, i cant see how it would be available if it was so dangerous. i reckon they didnt tighten the jubelies up enough and the hose popped off
johnono
aha, cant see how they start a fire though?
Dan318-is
i think them lot are on about the FSE power boost valves not the OEM ones
any experiences/advice on these?
johnono
adam has one on his 2.8, i guess heԚ´s happy with it, but then it is fairly modded
Dan318-is
hm mite give it a try
cheers guys
cheers guys
jmc330i
Wasnt it Adams that caught fire with the FSE - twice??johnono wrote:adam has one on his 2.8, i guess heԚ´s happy with it, but then it is fairly modded![]()
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
johnono
aha, then the myth is busted!!
E30Adam
You don't even need an adjustable regulator unless you have some serious modifications going on.
An FSE valve set alight to my engine twice that's correct so I wouldn't recommend them although I've had to buy another one because my engine won't run properly without one.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
Dan318-is
can someone please define "some serious mods" - what if i had new throttle body would i need one then?
jmc330i
Serious mods like Adams 2.8 M20.
You should be ok with your original one.
James
'91 325i Sport
'91 325i Sport
Dan318-is
saved me 80 quid then
jut out of interest how does it set your ar on fire
E30Adam
No, serious mods are things like MAF conversions and engine internal swaps of parts etc. Bolt on parts don't require one.318-is wrote:can someone please define "some serious mods" - what if i had new throttle body would i need one then?
I don't know how it managed to set my car alight, it just went bang and caught fire. Thankfully both times I was able to extinguish the fire rapidly so only minimal damage was done under the engine bay.
Dan318-is
thank christ for that. another e30 saved
i wont be purchasingone, i have also decided against a supersdprint header im jus gun aport polish my old one, so iv saved a lot of cash 2nite
what shall i spend it on
LOOPYLEE1965
when i fitted it i checked all the joints for leaks before i went out in the car no leaks (obviously) all the jubilee clips and pipes were secure or i wouldnt have drove it im not sure what make it is but didnt see any markings to suspect it is a fse was just told it was adjustable and was set up for a 325i sport it does seem to improve throttle response as the accelleration seems quicker ????Martinaston wrote:As long as you put it back together properly and the fuel lines are in good condition i can't see how you think it causes a fire ?
Dan318-is
if a 325i Regualtor goes on a 318is or 318i i would love to get one
if its an FSE pal theyr usually grey
LOOPYLEE1965
Dan318-is
haha pal iv spent my life on ere the last week
nearly 500 posts in 3 weeks lol
how sad am i!
only cos iv had nothing to do to the IS
how sad am i!
LOOPYLEE1965
Dan318-is
i sure am
but i aint been spammin, i have had so many queries about modding my IS and what kits to get etc this place has really helped me com to my sense about what im guna do to it etc
also good for throttle bodies and HnR cheap buys
LOOPYLEE1965
