M50 b2.5 supercharged
BigBavarian
Since my discussion with jhonno about supercharging my m50 and having been out in his S50 i want more power! What superchargers are people running and what would be the best supercharger for the M50. Any rough idea on prices would be very helpful also.
Richard
Richard
Cook318IS
ca automotive do a bolt on kit for the e36 (m50 obviously) for about £3,600 iirc. dont know an awful lot more than that thought im afraid!
link: http://www.ca-automotive.co.uk/products ... pZD04.html
1an
fowler
- Boost Junkie
yes A-tech (Ant)
does do a kit give him a tinkle !!!!!
gets you about 350 ponies i think
EX A-Tech Workshop bitch !!!
gone but not forgotten
jaistanley
Andrew.. You know I'm a mine(field) of technical advice and my consultancy fees will probably only run to a few select E30 spares for the project cer....
dicko
I am thinking of going this route my self , emerald ecu and may be a eaton m90 , would love a twin screw but they are serious money so. I will propably go with a eaton and standard c/r and 7/8 pounds of boost , I will need a good intercooler set up as the roots type blows make a lot of heat especially if you wind the boost up .
BigBavarian
Cheers for the input people, i have some calls to make!
Richard
Richard
Wouldn't a rotrex setup be a better bolt on solution, but you are probably looking at £5K by the time you've got the charger kit, sorted a decent intercooler & plumbing and then ECU and mapping.
penton08
now that just greedy! you already have a supercharged e30! why not try turbo? might even be a bit cheaper.
Daf318is
Interesting thread! Must keep an eye on this now that I have a spare M50 engine and I'm not really sure what to do with it
Now driving an E46 320D touring
dicko
A centrifugal supercharger would be a lot easier to install but they dont boost as well low down + roots blowers are cheap as chips and i reckon with a good charge cooler and bypass valve it would make a great m50 and on . I have changed my idea of lowering c/r since I read a book by Corky Bell on supercharging .
benjy
Be careful using his equations from that book. It is known to contain plenty of typos/errors. Ive found quite a few whilst researching a s/c set-up.dicko wrote: I have changed my idea of lowering c/r since I read a book by Corky Bell on supercharging .
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
dicko
Ya seen a couple of big ones , but will double check all calc,s before buying anything.
Is a good read though.
jaistanley
The corky bell book is a good starting place... But like the guys say there's a lot more comprehensive technical books out there. I might even have some left over after the great uni library clearout of 2004.. I shall have a look for you Andrew.
I think a supercharger is an awesome idea, and I would urge you to go for a large centrifugal type with either a very efficient air to air or a nice water cooled charge cooler. That way you can retain a higher compression ratio (keeping the charge temps down).
There are loads of chaps out there with more practical experience of these things, I'm just a uni book monkey.. lol
e30_Turbo
- Boost Junkie
Andrew, what's under the bonnet of that track day toy you have in the workshop?
You need nothing more, it's all there, just swap it in, make up some more brackets and you're sorted. I'm pretty sure that is a M90 so has plenty for a M50. It needs the mods doing you already know about so why not save the hassle and strap the fecker on, making the new bits as you need too. It'll still be much mich less than everyone else.
That just leaves you to persaude your Bro now, it would certainly be the most obvious way.
Unlike Jhonna I don't charge for my help
punk_sy
nice
cant wait to see what you will come up with
e30_Turbo
- Boost Junkie
Unlike Jai I don't charge for my help
Gunni
Why not tell us where so people are in the know.benjy wrote:Be careful using his equations from that book. It is known to contain plenty of typos/errors. Ive found quite a few whilst researching a s/c set-up.dicko wrote: I have changed my idea of lowering c/r since I read a book by Corky Bell on supercharging .
