Some pics of the offending manifold
A pic of the general scrapyard theme going on and a mate of mine in his power ranger suit (he popped through from Teesside for a wee while just to join in the pish taking)
The problem with the replacement fuel tank once the surface rust had been rubbed a bit
Bob making the best of a bad job by giving the original fuel tank a couple of coats of hammerite, will hopefully keep the MOT man off my back for a couple of years.
A peaceful neighbourhood transformed
Rear manifold is the upper one here,you can see how number 6 curves forward away from the bulkhead,it's a complete contrast to Lee's photo above.
Manifold laid out,hang on a bit,I have one from the top of the engine bay as well... I have your original front mani/pipe slightly modded to fit,I have a rear one based on your original that fits using a fresh manifold.This pair can be seen in the comparison photos and on the car in my thread,BUT,they blow from every joint due to my poor welding.I have an untouched(apart from slicing the flange off) front manifold.Just off to photobucket for that other piccie,wish I could put up multiple piccies!
How's that?
