whos Got a pioneer Avic head unit?
DJ_B4L
Post Sun Feb 22, 2009 1:07 am
whos got a pioneer avic headunit in their E30
does your screen catch the indicator when it comes out
PIONEER AVIC X1, X1R, X1 BT LATEST SATNAV DISK WITH LATEST MAPS AND ALSO UPDATES FIRMWARE £20 POSTED PM FOR MORE DETAILS
Number plate for sale E30 2 HRD open to serious offers only will suit any E30
Post Sun Feb 22, 2009 1:10 am
Yes it does (i don't have a pioneer one though).
DJ_B4L
Post Sun Feb 22, 2009 1:15 am
thinking of changing the E30 facia to a left hand drive any one done this? so the obc will be nearer to the indicator stalk and the headunit on the other side
Post Sun Feb 22, 2009 1:18 am
It has been done before. aceraf was in the process of doing it, not sure if has finished it or not. Drop him a PM 8)
BadDave
Post Sun Feb 22, 2009 1:36 am
My Alpine unit would hit the stalk if the original panel was still fitted.
LHD panel solves the problem.
OBC repositions OK, but poverty spec clock may need the wire's lengthened a little bit.
The other way,is to cut a little bit off the end of the offending stalk(yes people actually do that).
HTH
Post Sun Feb 22, 2009 1:37 am
Wouldn't that affect the OBC control on the stalk?
gcs325i
Post Sun Feb 22, 2009 1:41 am
DJ_B4L wrote:thinking of changing the E30 facia to a left hand drive any one done this?
Shedrool83 has done this and it looks rather good.
shedrool83
Post Sun Feb 22, 2009 7:53 am
Get yourself a lhd facia,its an easy swap and your problem will be solved plus you stock wont be butchered.
BadDave
Post Sun Feb 22, 2009 9:18 am
I'm noy sure exacly where the connections are on the obc stalk TBH.
I've definately seen it done on cars without OBC fitted.
I just use the LHD panel i've got.
You could remove the centre vents and relocate the unit in there and blank off the original din slot.
aceraf
Post Sun Feb 22, 2009 11:23 am
I was in the process of doing this, but with the hours i work haven't had time to finish it....basically as you can see from the pic above the right hand side of the panel doesn't fit 100% flush (you can see the groove that's supposed to be under the panel that goes under the clocks). I'm going to get this 100% before i finally finish fitting this!
I've got some time off from work in 3 weeks, and plan on getting quite a few jobs done on the car...will be posting pics up when it's done.
But yes, this is the cleanest way of doing it.
Breaking 325i Touring
Post Sun Feb 22, 2009 8:22 pm
Was is difficult to source the panel?
