Just to BTT this and get it back on topic.
After a long time wiring and testing all was well , before throwing the switch on the new ECU I became concerned that I had no comms from the PC to the ECU, So I took it apart to verify it was as its maker intended after its long trip accross the atlantic, all was not well.
It seems my MSnS ECU has a board fault causing the 5V to bleed to earth, its a manufacturing defect and will be covered by the supplier so apart from a shaort dealy, which I am well used on this project all should be well sometime next week
All the sensors are fitted, TPS modded to suit the D drive on the E30, now sporting M30 injectors too, once shes back in my hand the AFM is fianlly gonna be drop kicked into the skip and I'll be enjoying my all new E30 induction noise
Turbo hardware is all fabricated and ready to bolt up too now, kinda handy not using the car for a week, I got a lot done with a few late nights.
Will post up some pix of the story so-far if I ever remeber to take some
