Sawyer_E30
Post
Sat Feb 14, 2009 4:40 pm
Hi,
How can I make my
BLOODY boot stop vibrating with the bass?!!
What can I use to stop it from lifting?
E30: The only E-number you should be concerned about
GrindCulture
Post
Turn it off?
Not in E30s any more
n1tr0_9
Post
Sat Feb 14, 2009 4:42 pm
Dont put live fish in your e30?
Or you could try sound insulation foam/ sound deadening material
maxfield
Post
Sat Feb 14, 2009 4:43 pm
Check the nuts on the boot as my dad had a vibrating boot problem which turned out to be nuts working them selves loose.
Sawyer_E30
Post
Sat Feb 14, 2009 4:45 pm
GrindCulture wrote:Turn it off?
Oi! True though.
Sawyer_E30
Post
Sat Feb 14, 2009 4:46 pm
maxfield wrote:Check the nuts on the boot as my dad had a vibrating boot problem which turned out to be nuts working them selves loose.
Could you give me an idea which ones? I'll be install my battery boot kit tomorrow so wouldn't mind having a look then.
sati
Post
Sat Feb 14, 2009 4:53 pm
Brown Bread , DynaMatt - tryed and tested. . Tighten the Lock on the lid it helped a lot.
maxfield
Post
Sat Feb 14, 2009 4:54 pm
Sawyer_E30 wrote:maxfield wrote:Check the nuts on the boot as my dad had a vibrating boot problem which turned out to be nuts working them selves loose.
It was the ones on the boot hinges.
GrindCulture
Post
Sat Feb 14, 2009 4:56 pm
If it i that it might be worth either swapping them for locking nuts or put some loctite on the threads.
sati
Post
Sat Feb 14, 2009 5:20 pm
normaly the lock or latch come undone. so but tighting this you will pull the boot lid down more and will stop the rattling , wen i had my 2x w12gti the only thing stop it shaking was 5mm steel sheet weld to the lid and then dynamatted on top.
Sawyer_E30
Post
Sat Feb 14, 2009 5:45 pm
Thanks for all the input guys. Will attak the boot lid tomorrow, and tighten EVERYTHING I see!
da4x4turbo
Post
Mon Feb 16, 2009 7:46 pm
It's probably the plastic number plate surround vibrating against the rear of the car. I sorted it by putting a rag between the Plastic and the steel of the shell of the car.
While it was off I gave the whole area a good clean and a polish and wax too. Just in case some rust was trying to start in there.
Anyone who knows of an S50 B32/B30 E30 for sale, please let me know.
Autosparx
Post
Mon Feb 16, 2009 7:53 pm
The air is always gonna try to escape somewhere ! ( Causing mucho vibraton ) Try porting the shelf.
Mick
sati
Post
Mon Feb 16, 2009 8:08 pm
porting the shelf wont help stop the vibrating , but will help with sound, but if you got a ski hatch then there no need to bother.
