Bulkhead Repairs
MrWhite
Post Tue Feb 10, 2009 2:57 pm
Thought I'd stick up a few pictures of the butchery I'm doing to my car. The shell was in generally good contition with the exception of the battery tray area, which turned out to be a bit worse than I originally thought.
Was hoping it'd need just a couple of plates welded in to patch the rusty holes:
After some poking around and removal of the pedals it was clear that it was a bit worse:
So after getting in about it with various cutting tools it now looks like this:
There are a couple more small bits to cut out from the inside, its getting a bit tight for space though. Any more and I'd have had to move the dash, loom and probably the engine - No thanks!
Going to finish the cutting this weekend and hopefully find time to fabricate some bits to get welded in.
I'd welcome some useful comments. I've already been told that I'm insane, wasting my time and should have re-shelled it.
Post Tue Feb 10, 2009 3:53 pm
Brave man ! Looks like you got it all though - and lets face it most of the repair area won't be visible as it will be hidden by the battery when its all back together - Id just be sure to put a nice thick coating of hammerite on the repair followed by some waxoyl to stop it coming back. Good job mate - look forward to seeing the finished work ! 8)
MrWhite
Post Tue Feb 10, 2009 4:02 pm
Thanks rob,
I'll be approaching a bit of the welding from the inside of the arch. I've removed some patches of the thick PU joint sealing rubber stuff that is smeared on a lot of the welded areas. What is the best thing to use to replace this stuff. Would a good dose of waxoyl and underseal spray do the job?
rust never sleeps
Post Tue Feb 10, 2009 4:05 pm
What caused that to go so badly - a leaking battery i guess...
Top marks for going to such efforts at this time of year, oop North too :notworthy:
Dan320is
Post Tue Feb 10, 2009 4:33 pm
Have a gander at my touring project thread, you can see how I sealed the new joints/welds etc.
http://www.e30zone.net/modules.php?name ... c&t=116241
MrWhite
Post Tue Feb 10, 2009 4:34 pm
No idea, I bought it back in October. The PO said it had been sitting on the driveway for a few months. I guess it just went unnoticed for a while and the rust started munching. I'm sure somebody else on here must've had similar happen to their E30?
There are a few other small areas I'd like to patch up. If this repair is a success the other work will seem like a walk in the park. It is a lot more than I was expecting to do when I bought the car.
rust never sleeps
MrWhite
Post Tue Feb 10, 2009 4:38 pm
Need to type faster..
Thanks Dan, I'll have a read.
rust never sleeps
gooner1
Out humping Reindeer
Post Tue Feb 10, 2009 4:40 pm
Fair play MrWhite, a lot of cars have been scrapped for less than that.
While i,m here, iv,e recently noticed a very small amount of surface rust on my battery tray.
Nothing to worry about, will rub it down, etch prime and then spray it, but would it be worth drilling a few drai holes in it before i do?.
Dan320is
Post Tue Feb 10, 2009 4:48 pm
gooner1 wrote:Fair play MrWhite, a lot of cars have been scrapped for less than that.
Give it a stab and a scrape with a screwdriver :eek:
MrWhite
Post Tue Feb 10, 2009 5:03 pm
The thing I've found most difficult with this job is having to work around the equipment in the car. I'm running out of space to keep all the bits I take off to get to the rusty bits.
It was oh so close to becoming a seriously big/impossible job... you can see how near I've had to get to the main loom and its still touch and go as to whether I can finish this fix without having to remove the dash.
Also, the last little bit of rust can only really be cut out from inside the car as the back of the engine is in the way, as can be seen in these pictures:
It has been rather crudely covered in black silicone at some point (obviously leaking in the past). Not a good fix methinks.
You can see it in the far right of this picture
There is another little bad bit just where the inner wing (from the strut) meets the bulkhead.
rust never sleeps
ricey46
Post Tue Feb 10, 2009 5:09 pm
Fair play to you, glad you're fixing it!! :cool:
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
leeparkes
Post Tue Feb 10, 2009 5:44 pm
Fight the rust :guns:
MrWhite
Post Tue Feb 10, 2009 7:09 pm
On a side note - one of the rear jacking points (OS I think) is a bit rotten. Is it best to try to cut away rust and patch the holes or to chop a whole jacking point off another shell and fit that>?
Suppose it depends how bad the rust is.
rust never sleeps
MrWhite
Post Tue Mar 10, 2009 1:54 pm
An update from last weekend.
All the rust cut out ready for welding:
First plate in place:
And the rest....
A generous application of seam sealer:
Followed by zinc primer:
Now its ready for a top coat of some kind. I doubt that I'm going to spank loads of cash on brilliant red paint, I think it'll end up black instead. Still to fabricate the battery tray, from ally. It will be bolted in so it can be removed if required.
Progress! Next cut-n-weld job will be the jacking points, they are far from good.
rust never sleeps
ricey46
Post Tue Mar 10, 2009 3:24 pm
Good effort with the welding, looks a cracking job :cool:
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
MrWhite
Post Tue Mar 10, 2009 4:13 pm
Thanks, though I can't take all the credit. I persuaded a work colleague to do most of it for me.
rust never sleeps
Post Tue Mar 10, 2009 6:03 pm
Looks like a decent repair but the zinc primer should have gone on before the seam sealer.
MrWhite
Post Tue Mar 10, 2009 10:06 pm
I've heard and read opinions from both camps about whether to prime first and seal second or vice versa.
I chose to seal straight onto the bare welds because I read that polyurethane sealer sticks better to bare metal than paint does. It will also stick better to the metal than it will to primer. So long as the metal underneath is sound and properly cleaned...
Time will tell if I made the correct choice.
rust never sleeps
Post Tue Mar 10, 2009 10:32 pm
All shells are primed first then seam sealed/stone chipped when constructed at the factory. This is also the correct procedure in body repair. Bare metal should be etch primed first.
MrWhite
Post Tue Mar 10, 2009 10:54 pm
Every day is a school day :)
Thanks for the advice. I'll do it the other way round on the next welding job I tackle.
..So have I been badly misinformed about applying the seam sealer first or has anyone else heard that doing it the 'wrong way round' works better or worse?
rust never sleeps
Scruffymurphy
Post Tue Mar 10, 2009 11:40 pm
Good work. The rust was well advanced, how is the rest of the car? It would be unusual for for the rust to be that bad n one area.
MrWhite
Post Wed Mar 11, 2009 8:13 am
The rest of the car is pretty horrible to be honest but I've seen worse tackled by folk on here. It's not beyond saving but I've got more work to do, namely the jacking points. The underside of the car could do with a serious pressure wash and a good helping of underseal and waxoyl.
It spent the latter part of its life near the sea and I don't think it was very well looked after. Hopefully I can prolong the life of the shell by at least a couple of years.
rust never sleeps
