Oxford trackday for zoners on 27/02/09.
tomson
I've booked - see you all there!
Right, list to do on the 2.7 turd;
fit LSD
Oil & filter
New PAS pump & fluid
get tracking checked/adjusted
fit Eibach ARB's (buy new droplinks & bushes)
fit a set of 15" BBS & sort out some decent tyres - I dont fancy using the perished yingyongyangs I have in stock!
Any suggestions on where to get tyres and Eibach ARB bushes from??
fit LSD
Oil & filter
tomson
Edit- front brake pads too, any recomendations?
The car has Eurocarpart special grooved discs, which I robbed from a different car. I won't bother to change these as they are hardly used......
Might strip some of the interior too to save weight, Jon your 205 is in trouble!!
Good man!tomson wrote:I've booked - see you all there!
fit LSD
Oil & filter
Pads, EBC reds or yellows?
Tyres, try camskills?
Roll bars, try europerfomance?
See you there!
1. Jon_bmw: 205 gti
2. Turkey: e30 with m30b35?
3. Brian : PBMW 318
4. Mickey: PBMW 318
5. e30convert: 325i?
6. Winx
7. bss325i 318i with S50B30
8. DawieM3 M3 Track car 270bhp
9. Tomson 327i
3. Brian : PBMW 318
4. Mickey: PBMW 318
6. Winx
9. Tomson 327i
DawieM3
Looks like a good mixture of E30`s.
If +/- 120 is top then I will change to the shorter diff ratio
List of things to do,
1. change diff
2. Check all fluids
3. Check / change Brake pads
4. Give it a wash
5. Check weather forecast night before
6. Load relevant tyres / fuel
7. Pack a lunch and Liquid refreshments
Does anyone know if you are allowed vid cameras on board, and how strictly are the noise limits enforced. Not worried about the exhaust, its just the induction when you are galloping along a bit.
Look forward to meeting you all and hopefully it will be a sunny day.
Cheers,
Dave
1. change diff
2. Check all fluids
4. Give it a wash
Cheers,
Dave
E30 M3 Track car S14, 2.5l
2002, 2.0l fuel injected
E30 C2 2.7 Alpina
E36 M3 Evo
1602, - 2.5 S14
2002 E10 -M57 on e46 floorpan
335d - e92
320d -e92
Jag xj8 4.0l
Mitsu L200 animal
E30 C2 2.7 Alpina
E36 M3 Evo
1602, - 2.5 S14
335d - e92
320d -e92
Jag xj8 4.0l
Mitsu L200 animal
turkey
quite a lot of vids on youtube of the airfield day so would of thought as long as it's not going to fly around the place it would be fine, noise limits about 100db iirc
e30convert
There were no restrictions on video cameras at Abingdon as long as they were properly secured, quite a few cars had them in and have posted on the web..
For noise they limit at 100dB(A)... 1 car failed when we were last there so couldnt take part..
The only thing they wouldnt let us do was time a lap, as that implies competition!.. "its a track day and not a race!" is what they told us but there were some cars were very evenly matched for a lap or 4..
Looking forward to it.. although beginning to feel a bit concerned about all the special E30's turning up.. ours is just a standard 325i but feel that might change..
Brian28
Don't worry, I'll be well behind you in the (mechanically at least) standard 318e30convert wrote: although beginning to feel a bit concerned about all the special E30's turning up.. ours is just a standard 325i ..
For sale - E30 320i racer project - sold.
Jon_Bmw
- Dangerous when thinking
My 205 is in trouble with out your help! I've been trying to work out if the whole front end of my car is bent today...thankfully nottomson wrote:Edit- front brake pads too, any recomendations?
Video cameras are fine as long as its not the passenger holding it
Tommo, pads: I would really rate EBC yellows, I think they are fairly cheap for a 325 caliper as well. You won't fade them, you'll boil the fluid before that happens.
Dave do you know the DB of your car? I suspect it will be totally fine as its just a static test. They did pull in a porsche turbo that passed the static one but was excessively loud down the straight. It just got noise tested again, passed with a 97.7 out of a 100!
My list is getting longer, not shorter.
tomson
Anyone rate these or have any better suggestions ?
http://www.camskill.co.uk/products.php?plid=m4b103s93p0
tomson
Will have a look at these yellow ones, sound good.bss325i wrote:Pads, EBC reds or yellows?
Cheers for the camskill link - good site that!
Will check europerformance at work in the morning, I did have them in mind for the bushes.
I dug the ARB's out the garage earlier and found they are both 3way adjustable, I thought Eibach's were only 2 way on the back? Will have a proper look/measure in the morning.....
march109
Ta much. Would love to but I'm out can't (at the moment) get time off!bss325i wrote:That made me chuckle!march109 wrote:I might book up BUT I and my co-driver are complete cocks and liabilities of the highest order.
I have the spanner wielding talent of a spastic tied to his best mate a spanner, and the best way to describe my co drivers driving ability is about the same stevie wonder on acid getting a hand job whilst playing an excruciatingly difficult soduku puzzle with a blunt pencil.
I kid you not.![]()
Come on Gareth, do it!
If the situation changes I'll see if I can get in as a spectator, would love to see the mighty 205. But unlikely. Would love some zone support for my first crash in the track slag.
Jon_Bmw
T1r's are the best you'll get for under £50 a tyre. Although some 195/50 r888's arn't hugely more expensive...
Gareth, its mostly unmighty, in fact I am half way through bodging a sunroof plate on. Nice! On the up side, au revior to 10 kilos off the top of the car.
turkey
got the t1r's on the front of mine and i'm very happy with them, even more so as there where only £69 a pair with free postage of the bay!!!
DawieM3
Jon BMW,
The car was 102 db with the single GpN pipe I had on, but have changed it for a scorpion which is a lot quiter. I have managed Bedford before who are quite strict on noise so should be alright. Do they have any noise beacons around the airfield ????
Turkey,
What time you planning on leaving ?
Checked the brakes all round and gave it a wash, fired straight up after its winter slumber, also check all fluids as well, so besides changing the diff ( going shorter ), and loading her on the trailer with all the spare tyres, its already to go.
Which is the best route from Essex, M40 or M4 as M25 morning traffic is pants that time of day.
May just have to leave extra early to get off the 25 before it builds up.
cheers,
Dave
Turkey,
cheers,
Dave
E30 C2 2.7 Alpina
E36 M3 Evo
1602, - 2.5 S14
335d - e92
320d -e92
Jag xj8 4.0l
Mitsu L200 animal
E30 C2 2.7 Alpina
E36 M3 Evo
1602, - 2.5 S14
335d - e92
320d -e92
Jag xj8 4.0l
Mitsu L200 animal
Jon_Bmw
If its done bedford it will be fine.
You guys will have to leave quite early, aim to get there between 8.30-8.45 for a stress free journey.
Sunroof nearly plated up now, and i've got the open diff out(sounds easy, it wasn't with the box still attached
What time do we have to be there for Briefing?Jon_Bmw wrote:If its done bedford it will be fine.
Sunroof nearly plated up now, and i've got the open diff out(sounds easy, it wasn't with the box still attached)
Jon_Bmw
I think its 9, or is it 9.30. I really don't remember, let me check an old email...
Jon_Bmw
"Please aim to arrive for signing on from 9.00am. Being late might mean you miss the driver's briefing and/or some of your driving sessions. The driver's briefing will be at 9.30am"
tomson
Jon_Bmw wrote:aim to get there between 8.30-8.45 for a stress free journey
Jon_Bmw
That was for the m25 car park boys!tomson wrote:Jon_Bmw wrote:aim to get there between 8.30-8.45 for a stress free journey
winx
mmm, that'll mean a lie in for me then! get up at 8.30 bit of breakfast and out the door at 9.50
turkey
Hey Dave, Not planned what time to meet yet but can be sure the m25 will be packed in certain bits, only thing is we'll be bound to hit the rush hour at some point, i might plan leaving around 7ish but not looked at the route yet, Could meet up on the way too, don't know what time you plan leaving?
DawieM3
As I`m towing I will leave a lot earlier than that,( 05.30 ) latest can`t be arsed with all the W---ers out there in the morning traffic
, especially with a trailer. All you need is one accident and you could end up sitting for most of the day
. I`m up to birmingham on Thursday for work so may go the M40 and see. You ideally want to be off the M25 by 7.00am though
Can always pull into a services for a relaxing stress free nap or for a bite once the 25 is behind you.
Can`t be as bad as towing to Oulton Park, drive all day, then tow back home again all in the same day, however the drive back is relaxing as you are mellowed out having just had your speed fix for the day. I must be Nucking Futs
, but have done this on a few occations.
Oh well roll on the 27th and am looking forward to it.
Cheers,
Dave
Cheers,
Dave
E30 C2 2.7 Alpina
E36 M3 Evo
1602, - 2.5 S14
335d - e92
320d -e92
Jag xj8 4.0l
Mitsu L200 animal
E30 C2 2.7 Alpina
E36 M3 Evo
1602, - 2.5 S14
335d - e92
320d -e92
Jag xj8 4.0l
Mitsu L200 animal
tomson
I cant seem to find a website that lists EBC Yellows for the E30Jon_Bmw wrote:Tommo, pads: I would really rate EBC yellows, I think they are fairly cheap for a 325 caliper as well. You won't fade them, you'll boil the fluid before that happens.
Can anyone point me in the right direction for these please and a ballpark figure on the cost too would be helpful
Jon_Bmw
Its hard work, it took me ages to find them for my 205. I am making progress on your 325. Is there only onw caliper type for a 325? IE not girling or bendix?
Jon_Bmw
According to this site:
http://www.modacar.com/manufacturer/EBC ... +Pads.html
You need:
DP4779
Pad shape and dimension:
You need:
DP4779
Jon_Bmw
Tom, I am pretty sure DP4779 is the right pad.
Basically, there standard fit is dp779, green is dp2779, red is dp3779, yellow is dp4779.
Interesting all are available from here, but you have to maually put the part numbers in:
http://www.ebcbrakesdirect.com/search/d ... car&t1=pad
You can also choose blue stuff(dp5779), but you won't need these even with the mighty 12v.
tomson
I didnt get those pads earlier Jon so will bell you tomorrow ref the "group buy" !
Jon_Bmw
Yep, no worries. If I don't answer its because I am in a lecture or something.
I need DP4426 as I won't remember the number tomorrow. I'll sort you out the monies at the trackday, or before if I pick them up.
TRACKDAY IS FULL according to their site. If you are still keen, ring them up and you may get on.
tomson
My mate now wants to come, can I add him as a passenger on the day or should I do it beforehand do you think?
Will order the pads in the morning
Jon_Bmw
You can do it on the day, its £10 iirc. £20 for a driver.
Yep, order my set as well, you have to select the cheaper postage option(48 hours) and its free.
turkey
Your right there bout getting the M25 out the way early, bad enough sitting there in the work van let alone my noise box and the worry of over-heating before even getting there!DawieM3 wrote:As I`m towing I will leave a lot earlier than that,( 05.30 ) latest can`t be arsed with all the W---ers out there in the morning traffic, especially with a trailer. All you need is one accident and you could end up sitting for most of the day
Can`t be as bad as towing to Oulton Park, drive all day, then tow back home again all in the same day, however the drive back is relaxing as you are mellowed out having just had your speed fix for the day. I must be Nucking Futs, but have done this on a few occations.
Oh well roll on the 27th and am looking forward to it.![]()
Cheers,
Dave
Looks like an early night before and leave early then! Can't come soon enough at the moment, just hope it don't get cancelled over weather!
winx
picked up my shocks and springs tonight so hopefully get it all on this weekend ready for the 27th!
Jon_Bmw
Did you get the suspension on Winx?
The LSD is on, the top mount bearing replaced, the sunroof is plated(very council, make sure you look at my bodging on the 27th) Brakes fluid changed.
Test drove it for the first time tonight, bearing in mind you are supposed to only use it lightly for the first 50 miles then do another £18 oil change
Its fucking brilliant, au revior wheelspin, hello grip. It pulls you through corners nicely
Also found out why it is tugging to the left when off the throttle and on the brakes, the NSF caliper is binding on
There is always something to be doing on this frigging car. Luckerly I have recently refurbished a spare set I had, excuse the fact they are red, some other monkey painted them like that.
