In order to make my life easier does anyone know how you remove the barrel and what normally causes them to jam ??
Any help would lead to a peaceful homelife this weekend....
Now that sounds far to easy.. Can it be that easy ??elliot wrote:mine did this not so long back. quite easy to remove
remove the door trim, locate the back of the barel and remove the plug which may be attached
there should be a flat clip which hlods the barel tight to the door, this can be removed with a large flat headed screwdriver.
make sure you recognise which way round the barrel comes out.
spray with loads of wd40.
reverse the above for refitting
you reassure me with your confidence... If you're wrong I'm coming to leeds !!!!!dazleeds wrote:yeppp
If it works I'm gonna throw a party to celebrate..dazleeds wrote:![]()
it can be a bit fiddly but if you have a bit of patience it is easy enough and as described above mate gotta do both on my other delphin 1day haha goodluck mate Daz
Cheers guys.. beers on meBrianmoooore wrote:When you've got the lock barrel assembly out, check that the over centre pivoted bit at the back end moves freely.
Insert the key and turn it both ways while holding the outer barrel. End bit should flip from side to side.
Well I gave it my best shot !!! The barrel is absolutely fine. The problem lyes with the locking mechanism. When you turn the key it moves a lever up and down which is supposed to sit nice and neatly between this fork type thingy which activates the lock. This fork type thingy is no longer secure so I keeps jamming and locking up the barrel.peejay wrote:Well, is it sorted?if so mines a pint of Stella !
