I've made a lot of progress on the car since I first picked it up, but only now started the thread.
Maybe restoring is a bit of an exageration, but its way further than I have ever gone with a car before. Any hint of a problem and they normally get PX'd in for something else.
This cars different, as I wanted bit of a project to to get stuck into. Anyway, as you'll see from the photos, its more than I bargained for.......
When I bought the car there was a very slight amount of damp in the passenger foot well. There is a common blocked drainage problem that can cause this, but it can also be bulkhead rust which is a whole lot worse. Generally the car seemed quite rust free in the normal areas, so I wrongly assumed blocked drain.
This is what I found under a shat fibreglass repair
peeled away the shat
Oh dear
I think other E30's have been scrapped because of this as people don't want to be messing about near the main loom
Anyway, out comes the grinder
the rust at the top was all ground away as well, I always take it right back to clean metal
This is just the near side front wheel wheel arch.
This was some real major welding, took 5 plates in total and fair amount of fabrication to get this all patched up. I don't want this turning into a big money resto, hence me making up plates from fresh steel rather than buying expensive panels from BMW. Luckily I get the metal from work
Now looks like this from inside
and this from the outside, although now its been seem sealed and undersealed
