M50 swappers! what brake servo have you used???
leeparkes
Post Mon Jan 26, 2009 8:02 pm
As above really.
is there a direct fit one?
braking performance too...
also do i keep the E30 master cylinder?
thanks (in advance)
blackcountrybimmerman
Post Mon Jan 26, 2009 9:26 pm
Lee, I thought I saw it mentioned about a Golf GTi servo?
There are so many engine codes and conversions I get confused.
It doesn't look like it does in my sig pic anymore
BigBavarian
Post Mon Jan 26, 2009 10:32 pm
Ive used a plastic winged clio one, used e30 master cyl just put a spacer in the master cyl as the shaft on the lio one is shorter than the e30 servo. Golf gti one works aswell. If you need a servo give us a call theres a bloke near us that frags them.
Richard
leeparkes
Post Mon Jan 26, 2009 11:15 pm
BigBavarian wrote:Ive used a plastic winged clio one, used e30 master cyl just put a spacer in the master cyl as the shaft on the lio one is shorter than the e30 servo. Golf gti one works aswell. If you need a servo give us a call theres a bloke near us that frags them.
does the golf one need any 'modding' to fit,
is the braking effected using a smaller set up?
is the plastic winged clio the one that came out roughly on a v-reg?
thanks for the offer but i live in the west mids so finding one wont be problem!
Post Mon Jan 26, 2009 11:19 pm
I believe that the VW Golf servo bolts right in without any modification from what I can remember.
zimmer-320i
Post Mon Jan 26, 2009 11:34 pm
firstly let get one thing straight as there are 3 diffrent parts to what were talking about and using the wrong names for parts your discribing is going to confuse, no you cant use a e30 master cylinder if using a golf one or french crap. but yes you can use the e30 servo ( which is the black part btw) not named the master cylinder ethier!
the golf mk2 ones fit just fine there 23 quid from gsf or theres a few on the bay, take ya pick new or old,
and to just remind you.......... the servo IS NOT the master cylinder!!
rant over
:x
zimmer-320i
Post Mon Jan 26, 2009 11:42 pm
FOR THOSE AT THE BACK WHO WERNT LISTENING
leeparkes
Post Tue Jan 27, 2009 12:04 am
zimmer-320i wrote:firstly let get one thing straight as there are 3 diffrent parts to what were talking about and using the wrong names for parts your discribing is going to confuse, no you cant use a e30 master cylinder if using a golf one or french crap. but yes you can use the e30 servo ( which is the black part btw) not named the master cylinder ethier!
rant over
:x
the servo (black part) is being changed ready for an M50 conversion as the E30 one comes into contact with the inlet manifold.
as you know i have a brake issue in another thread and it has been pinned down to the master cylinder,
whilst im sorting out this issue i may aswell tackle the servo 'downsizing' while im there.
kill two birds with one stone!
zimmer-320i
Post Tue Jan 27, 2009 12:41 am
well the way you were going on in last thread you wanted a master cylinder then you start another thread after beeing told a golf one fits!!!
Post Tue Jan 27, 2009 1:57 am
Golf one isn't a direct fit either iirc..
The Clio one is regarded as being the best currently..
Post Tue Jan 27, 2009 9:41 am
:lol: @ zimmer
Clio servo and E30 master cylinder, last conversion I did the brakes actually felt/worked better than with the E30 servo
leeparkes
Post Tue Jan 27, 2009 2:08 pm
DanThe wrote:Clio servo and E30 master cylinder, last conversion I did the brakes actually felt/worked better than with the E30 servo
Thats what i wanted to know :thumb:
Zimmer,i cant see how you got confused!
i opened a thread in the tech section about a brake problem,it was pinned down to the 'master cylinder' so thats that thread sorted and finished with.
i didnt want to buy a new E30 master cylinder if in a few months down the line id need a different one to fit the clio/golf servo (M50 conversion)
hence why i opened a thread in the 'engine swap section',
asking which was the best combination to use,in the monster m50 sticky there is mention of using an audi master cylinder!
are we clear now? :D
Post Tue Jan 27, 2009 6:03 pm
It doesnt take much :)
Post Tue Jan 27, 2009 6:13 pm
:snigger:
dicko
Post Tue Jan 27, 2009 7:57 pm
You Can use the original e30 Master cylinder with a clio servo I did and it works fine , you need to fit alonger treaded bar into the actuator rod as the clio one is shorter and I had the same result as Dan better brakes than before , and as for the french crap statement , the one I got was manufactured by "ATE" the same as the e30 original .
Post Tue Jan 27, 2009 8:04 pm
All the clio servo's ive had have been Bosch, if they were made by valeo or whatever other french place I would have probably used a golf servo :P
eko
Old timer
Post Tue Jan 27, 2009 8:14 pm
your the one likely to cause confusion here :mad:
zimmer-320i wrote:no you cant use a e30 master cylinder if using a golf one or french crap. but yes you can use the e30 servo
Wrong!
dicko
Post Tue Jan 27, 2009 8:15 pm
Ya I though it would have been valeo , but when I cleaned it up there was the Ate sticker ,
Jon_Bmw
Dangerous when thinking
Post Tue Jan 27, 2009 8:21 pm
Plastic winged clios have immensly over assisted brakes IMO. I have to be careful when in the old dears DCI chariot.
By using all the parts, does this translate to really 'powerful' assistance in the e30 Dan?
dicko
Post Tue Jan 27, 2009 9:37 pm
I dont find them overly assisted and most diffinetly not like french cars I have driven( overlly soft ) they are not to hard you have to apply a fair bit of pressure to lock up even in the wet , they may be a little soft for a track car but I find them great really easy to judge where the limit is .
Post Tue Jan 27, 2009 9:52 pm
Jon_Bmw wrote:Plastic winged clios have immensly over assisted brakes IMO. I have to be careful when in the old dears DCI chariot.
First time round when I originally discovered the Clio servo would fit in the E30 bulkhead I used the Clio MC also, instead of using the recommended 20 year old golf servo and cut a piece of rod to lengthen the actuator I went on a mission in the local scrappy with an E30 servo/MC in hand looking to find something that would simply 'bolt in wholesale'
Like you say the clio brakes are pretty sharp, which made me think it was a good plan, but the MC is only about 20-21mm diameter which isnt ideal for the E30 calipers, it stopped the car well but the pedal was too long, if the abs cut in big time the pedal would sink too far and leave you with nothing!
Ive also tried it with a similar Bosch MC from a citroen van which was 23mm straight through, but this had the opposite effect, useless on the fronts but kept locking the rears up, so I bolted up a 750i MC with a spacer which turned out to be balanced about right but the servo just hasnt got the guts to move it enough so the pedal is very hard.
Havnt tried any others, but in my experience the E30 MC is by far the best 8)
leeparkes
Post Tue Jan 27, 2009 11:26 pm
DanThe wrote:First time round when I originally discovered the Clio servo would fit in the E30 bulkhead I used the Clio MC also, instead of using the recommended 20 year old golf servo and cut a piece of rod to lengthen the actuator I went on a mission in the local scrappy with an E30 servo/MC in hand looking to find something that would simply 'bolt in wholesale'
Very usefull information,
Thanks!
leeparkes
Post Tue Jan 27, 2009 11:27 pm
does anyone have a picture of the clio servo 'adjusted' to fit the E30 master cylinder?
eko
Old timer
Post Tue Jan 27, 2009 11:48 pm
leeparkes wrote:does anyone have a picture of the clio servo 'adjusted' to fit the E30 master cylinder?
The servo doesnt need any adjustment,you just put a piece of threaded bar into the end of the master cylinder then bolt upto the servo,effectively extending the push rod.
I am using standard E30 M/C on mine and brakes are better than standard servo.Benjy is using standard E30 M/C but his has ABS too,again brakes are excellent.OBs is using 23mm Audi M/C and hard to tell the difference to E30 M/C to be honest.
leeparkes
Post Tue Jan 27, 2009 11:58 pm
Ahh,i see.
thanks
tomson
Post Wed Jan 28, 2009 3:23 pm
Not all Golf servos are suitable, if you choose to go for a Golf one then take your E30 MC with you to try it. The problem I came across when looking in a breakers was the opposite to what people have had to do with the Clio servo, the push rod in the servo was too long so when the MC was bolted to it the piston was almost fully depressed. The outcome of this would either be the brakes being locked on all the time or you would only get 25% of the intended travel on the MC piston. This is a pain as the lovely little VW servos, circa Mk1 Gti's iirc, are perfect for the much larger S50 inlet plenum but probably makes no difference on your M50 one.....
dicko
Post Wed Jan 28, 2009 6:09 pm
Actually you are right Mr Tomson coming to think of it ,the clio actuator rod is too long , not too short as I had said .
Details fade very rapidly with time !
Karan
Post Wed Jan 28, 2009 10:01 pm
i happened to have one in the for sale section attached to a 25mm 750 master cylinder :D
tomson
Post Wed Jan 28, 2009 11:09 pm
dicko wrote:Actually you are right Mr Tomson coming to think of it ,the clio actuator rod is too long , not too short as I had said .
I was talking about the VW one, you wont find anything French on one of my BMW's winkeye
leeparkes
Post Thu Jan 29, 2009 2:52 pm
so does the clio servo need some of the push rod cut off,
or use a spacer between the servo & master cylinder.
BigBavarian
Post Thu Jan 29, 2009 5:33 pm
The clio servo i used needed a spacer between the servo and the master cylinder, think it was approx 15mm.
Richard
eko
Old timer
Post Thu Jan 29, 2009 5:45 pm
leeparkes wrote:so does the clio servo need some of the push rod cut off,
It needs a spacer.
Cut the threaded bar to about 15-16mm in length and slide it in the back of the M/C :wink:
**BANNED**
Post Fri Jan 30, 2009 12:54 pm
It needs a spacer.
Just what I have done,I discovered that not all Clio servo's have a yoke compatable with the E30 relay box,the first one I bought the yoke was too short and I am fairly certain I buggered the servo seals when I welded the E30 yoke to the pushrod :o: The second one bought and fitted this week was spot on and the brakes are no heavier than the standard car.
