how to fit m tech 2 side pods/skirts?
snoops
Major Helmet
Wed Jan 30, 2008 12:27 pm
can anyone tell me how to fit m tech 2 side pods/skirts?
aceraf
Wed Jan 30, 2008 3:44 pm
If anyone has a guide for fitting the kit then i could use a copy aswell.
I think if there is one out there then it should probably be made a Sticky as i'm sure there's plenty demand for it.
Breaking 325i Touring
abelai
Wed Jan 30, 2008 4:22 pm
I believe there are templates that you can still buy from BMW that stick to the car and you drill accordingly. You can see them on realoem
If I can't fix it I'll f**k it up so bad nobody can!!
aceraf
Wed Jan 30, 2008 4:27 pm
abelai wrote:I believe there are templates that you can still buy from BMW that stick to the car and you drill accordingly. You can see them on realoem
I can get to this
http://www.realoem.com/bmw/showparts.do ... g=51&fg=95
but it doesn't give you any guide's there. Just lists part numbers.
abelai
Thu Jan 31, 2008 8:31 am
No not there. Here:
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
If you go to your dealership and ask some parts have fitting instructions, be nice and they might print them off. I'm collecting some parts on friday I shall ask.
jon_d_h
Mon Aug 11, 2008 3:51 pm
Im also stuck with fitting the side skirts and side pods. I dont know where to start with them. Have any off you had any luck?
corkie
Fri Aug 29, 2008 8:07 pm
me to iput this up before and got nowhere,it must be top secret lol.
e30
gazza
Sun Aug 31, 2008 9:59 pm
lads pm me a email address and ill try and send the original bmw instructions (in pdf format) you can buy the template but its about £20 to. but then chuck it after use ...i fitted mine without it just make sure you buy all the correct clips its not as hard as you think i used one of the clips with the 2 pins removed as a guide for the drill and lined the sill up and marked it it dont have to be perfect as there is a bit of leeway on the sill for the clip to move
corkie
Tue Sep 02, 2008 5:50 pm
you have pm
e30
gooner1
Out humping Reindeer
Tue Sep 02, 2008 5:52 pm
Sorry to jump in, but is there one available for the Zender skirts?
corkie
Sun Sep 07, 2008 10:02 am
bump winkeye
e30
2_stroke
Sun Sep 07, 2008 11:25 pm
gooner1 wrote:Sorry to jump in, but is there one available for the Zender skirts?
i have the best fitting kit for zenders you can get it in b&q its called no nails :mad:
jon_d_h
Mon Sep 22, 2008 1:07 pm
I am now half way through fitting the side skirts and pods but have had to stop as BMW sent me the wrong clips :-x . I have been taking pics through doing it so will make a thread on how to do it when im finished as I found it hard to get infomation on this topic.
scottidog
Thu Sep 25, 2008 8:47 pm
dont they just clip into the holes where the original rubbing strips go down the car, and clip on at the bottom.
JamOnIt
Wed Dec 10, 2008 8:44 pm
Has anyone got a copy of the PDF file Gazza mentions in this thread?
cactusjacks1
Thu Dec 11, 2008 1:06 am
gazza wrote:lads pm me a email address and ill try and send the original bmw instructions (in pdf format) you can buy the template but its about £20 to. but then chuck it after use ...i fitted mine without it just make sure you buy all the correct clips its not as hard as you think i used one of the clips with the 2 pins removed as a guide for the drill and lined the sill up and marked it it dont have to be perfect as there is a bit of leeway on the sill for the clip to move
You have PM
cactusjacks1
Thu Dec 11, 2008 1:07 am
You have PM
Chase007
Thu Dec 11, 2008 1:24 am
I want to know how easy is it to take it off with out mashing it up, plus once taking off is it best to buy all new fixings to go back on or just some certain bits? :)
JamOnIt
Fri Jan 02, 2009 2:17 pm
the PDF for fitting the side pods (infact the whole kit) is mentioned and linked to at the beginning of mrlees front and rear fitting guide on the zone wiki.
http://rapidshare.com/files/147753716/M ... g.pdf.html
or copy and paste that into a new browser window and wait 45 secs.
I hope this helps you all and thanks mrlee for the info and great wiki article.
mrLEE30
Sat Jan 10, 2009 1:02 pm
your welcome!
once i pull the tech 2 kit off of my sport (to send to the paint shop) i will update this wiki article to include the side pods.
mrlee
