325 radiator of aircon car
UweM3
Post Tue Jan 06, 2009 4:54 pm
Does anybody know when the classifieds will be up and running again?
I am after a radiator of a 325 from 9/87 onwards (does this mean face list??) but MUST be from an aircon model.
Even if you don't have one for sale, I am keen to see a picture of it. Or even better can anybody compare this rad to a non aircon model?
Have been told that the aircon one is taller and has the overflow tank included.
TIA
ian332isport
Post Tue Jan 06, 2009 5:37 pm
Uwe,
You may find it easier to find an E36 328i radiator.
Ian.
Post Tue Jan 06, 2009 7:15 pm
A/C is taller yes but the overflow tank is still separate
tomson
Post Tue Jan 06, 2009 9:48 pm
Simon13 wrote:A/C is taller yes but the overflow tank is still separate
Correct, pre facelift ones are thinner too......
UweM3
Post Wed Jan 07, 2009 11:21 am
thanks for you input chaps.
UweM3
Post Wed Jan 07, 2009 11:23 am
ian332isport wrote:Uwe,
Ian.
Ian, I am torn between maximum cooling (E36 M3 rad) or the cleaner engine bay with the tank attached to the rad. What is your experience?
Also browsed lists and it seems that the diesel rad and the M3 rad is the same P/N?
ian332isport
Post Wed Jan 07, 2009 5:31 pm
UweM3 wrote:Ian, I am torn between maximum cooling (E36 M3 rad) or the cleaner engine bay with the tank attached to the rad. What is your experience?
I've only ever used an E36 M3 radiator with my conversion, so can't really comment on anything smaller. I'm certainly not on the edge of overheating, and have never had any temperature issues. You may well find a 328 radiator is plenty big enough. As you say, it makes for a cleaner install.
Also browsed lists and it seems that the diesel rad and the M3 rad is the same P/N?[/quote]
Not according to the ETK. That's not to say the diesel rad is any smaller though.
Ian.
e301988325i
Post Fri Jan 09, 2009 5:47 pm
Euro car parts p/n 203110660 manual 325i with aircon. Have this fitted on my car, it has about 4 inches extra core at the bottom, uses the same hose mounts and other fittings. Cheers
I said:
e30topless said:
lock the wife in there
UweM3
Post Sun Jan 11, 2009 7:27 am
e301988325i wrote:Euro car parts p/n 203110660 manual 325i with aircon. Have this fitted on my car, it has about 4 inches extra core at the bottom, uses the same hose mounts and other fittings. Cheers
thanks for the confirmation. Is this a rad WITH expansion tank or seperate?
e301988325i
Post Sun Jan 11, 2009 10:34 am
Without expansion tank. . . uses the original header tank. Ps) mine's an '88 facelift
I said:
UweM3
Post Sun Jan 11, 2009 8:13 pm
thanks mate
Post Sun Jan 11, 2009 8:19 pm
Ive run a 325tds rad on my 24v swap and it appears identical to the M3 one.. Even had the fan switch hole..
UweM3
Post Mon Jan 12, 2009 9:23 pm
Jhonno wrote:Ive run a 325tds rad on my 24v swap and it appears identical to the M3 one.. Even had the fan switch hole..
that's what I found when looking through a parts list of a no name rad supplier. Thanks for confirming this
Post Mon Jan 12, 2009 10:39 pm
What the rad being used for engine wise?
rwd1
Post Thu Jan 15, 2009 6:34 pm
can anyone tell me what the difference is between the M3 and the 2.5td radiator (apart from £25 plus the VAT). they seem to have the same dimensions but not sure it hose holes are the same or not. They do seem have diffrent part numbers.
Need replacement rad for rally car to staop overheating on tight twist stages on hot days
Brian
UweM3
Post Fri Jan 16, 2009 6:07 pm
bss325i wrote:What the rad being used for engine wise?
S50B32
Post Fri Jan 16, 2009 6:14 pm
S50B32
Is that going in your black M3 that i saw at the ring last summer?!
rwd1
Post Fri Jan 16, 2009 10:38 pm
in a 325 e30 rally car
cheers
Brian
