Relay location for rear foglights
kevin316i
Post Sun Jul 17, 2005 12:58 am
Can someone confirm which relay is for the rear fogs? The're not working so I need to work my way through the various components.
Can you do any tests on a relay to verify its OK, or is just a case of replacing it with a known good one?
smithy318i
Post Sun Jul 17, 2005 8:11 am
I wasn't aware that there was one for the rear.
smithy318i
Post Sun Jul 17, 2005 8:31 am
Thought there wasn't one. And guess what! There isn't one.
It could be your switch or your fuse.
kevin316i
Post Sun Jul 17, 2005 10:37 am
Thanks guys. Well, that should make the job a little easier, as the owners handbook was referring to K4 and K9 on the fuses and relay info page, so this confused me. I have checked the fuse already and have tried some repalcement bulbs, so I guess I should replace the switch. There is an old one in the garage somewhere.
