Can someone confirm which relay is for the rear fogs? The're not working so I need to work my way through the various components.
Can you do any tests on a relay to verify its OK, or is just a case of replacing it with a known good one?
Relay location for rear foglights
smithy318i
I wasn't aware that there was one for the rear.
smithy318i
Thought there wasn't one. And guess what! There isn't one.
It could be your switch or your fuse.
kevin316i
Thanks guys. Well, that should make the job a little easier, as the owners handbook was referring to K4 and K9 on the fuses and relay info page, so this confused me. I have checked the fuse already and have tried some repalcement bulbs, so I guess I should replace the switch. There is an old one in the garage somewhere.
