e30 318is block q!
deepdishtj
Post Sun Jan 04, 2009 3:12 pm
hi havent posted on here before!! so i thought i would! is there any 2.0 block that can replace the 318is block. there for making it a 2.0???
rix313
Post Sun Jan 04, 2009 3:30 pm
You can increase the CC by changing the crank shaft, some one has done it before.
GrindCulture
Post Sun Jan 04, 2009 3:34 pm
In order to get to 2L you'll need to either replace the crank with an M47 item and use M44 pistons, or use S50B30 pistons on the M44 crank. S30B30 pistons with an M47 crank will give 2.1L.
http://www.e30zone.net/e30zonewiki/inde ... roker_Info
Not in E30s any more :(
DHFiS
Post Sun Jan 04, 2009 3:40 pm
rix313 wrote:You can increase the CC by changing the crank shaft, some one has done it before.
Crank from the M47 2.0 diesel engine is the one
deepdishtj
Post Mon Jan 05, 2009 5:38 pm
ok cheers guys!
Daf318is
Post Tue Jan 06, 2009 8:31 pm
I looked in to doing this but it get's very expensive, just be warned that the bits to do this will run you up a very big bill!
Daf
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
GrindCulture
Post Tue Jan 06, 2009 8:36 pm
The second M42club link I've posted today, I thought I was on my way to curing my 4 pot illness.
http://www.m42club.com/forums/showthread.php?t=6866
Some very helpful info in there about rods, piston shaving, CRs and prices.
