SPRINGS
if i had the opposite question and asked i have a 325 sport and have standard springs and want to lower it, then i would still need compressors??!!!! ive done rear ones better always left it to my mates to do them 4 me!!maxfield wrote:Rears are a piece of cake.
The fronts will need a spring compressor.
maxfield wrote:Yes, you will still need spring compressor.
Have you ever seen a fully loaded spring slip?![]()
Seen one slip out of the compressors and fly across the garage I used to work at and take a chunk out of the brick wall like a sledgehammer (was off the front of a 7.5 ton truck)
Regards,
Ian
Kingdoms are run by Kings, Dictatorships are run by Dictators, England must be a Country.
