BBS Paint
I have a set of 14" BBS Cross Spokes and would like to know what paint to use to re-spray them.
Now in the past I have used "Hammerite silver smooth" on a bottle top and it looked fine but it may have needed to have a clear coat on top.
Ideas and comments will be well recieved.
Cheers, Mart.
Cheers, Mart.
mattsbmw
Use standard wheel silver from your local motor factors, usually about £3 a tin. topped off with some similar priced lacquer. job done
As always the key is in the preparation.
Thanks mate, so would my Hammerite smooth silver do the job as you dont have to use a primer but the wheels would be prepared (keyed) and a coat of lacquer added as well.
I have to say all four centre caps are new so I hope the paint wil match.
Mart
Mart
scootlife
I think that the BBS do have a specific silver, cant remember which....!!!! Im sure someone will tell you
mattsbmw
I doubt Hammerite would match, just a case of trial and error i am afraid. unless you can get the paint code for the BBS colour.
scootlife
Polaris Silver , i think is the colour....
Matt what was the stuff you used on yours ? they did come out well.
mattsbmw
I used some tetrosyl stuff from a motor factors, was cheap stuff, it wont match though as it was a few shades darker than the BBS colour so i ended up spraying the centre caps aswell.
leeparkes
felgen silver/silberscootlife wrote:I think that the BBS do have a specific silver, cant remember which....!!!! Im sure someone will tell you
no idea what the paint code is
Thanks guys , I may just try the Hammerite as the coverage is superb and you dont need a primmer.mattsbmw wrote:I doubt Hammerite would match, just a case of trial and error i am afraid. unless you can get the paint code for the BBS colour.
And I will spray the caps as well as it wont take too long.
leeparkes
ive used hycote wheel silver in the past and they turned out well.
mattsbmw
Sounds a good plan, then at least you know the colour will matchmartauto wrote: Thanks guys , I may just try the Hammerite as the coverage is superb and you dont need a primmer.
I'd guess that lacquer sprayed onto Hammerite wouldn't be a good idea, as they would probably react horribly and go all crinkly.
Good point mate, I`ll do a test on something first just to check.Speedtouch wrote:I'd guess that lacquer sprayed onto Hammerite wouldn't be a good idea, as they would probably react horribly and go all crinkly.
scootlife
Not a fan of Hammerite, seem to remember last time i used it you had to reapply other coats within a certain amount of time otherwise you would get a reaction.
gooner1
- Out humping Reindeer
Nogaro ?scootlife wrote:I think that the BBS do have a specific silver, cant remember which....!!!! Im sure someone will tell you
OK , keep us all posted on this one as I`m sure I am not the only one who is willing to give it a go but would really like to know the "proper " shades / colours etc.gooner1 wrote:Nogaro ?scootlife wrote:I think that the BBS do have a specific silver, cant remember which....!!!! Im sure someone will tell you
Thanks for all the replies so far.
Cook318IS
i looked into it a bit and felgen silber is the normal silver and nogaro is the gun metal grey looking paint.
Im gettin my bbs's done with nogaro centres with felgensilber dish and lip... eventually!
Where can you buy "Felgen Silver " from , and what laquer would you recommend mate??
Chris-W
leeparkes
you learn something new every day!Chris-W wrote:It's Polaris. Felgen Silber just translates as wheel silver. It's the same colour.
Just an up-date,Speedtouch wrote:I'd guess that lacquer sprayed onto Hammerite wouldn't be a good idea, as they would probably react horribly and go all crinkly.
I srayed a test piece today with Hammerite silver smooth and put lacquer on top about 90 mins later.
So far there has been no reaction between the two so if this continues ,then I will be going down this route for the BBS.
The car is being used as my sons wedding car (his request) so time is very short ( 7 February is the day ) and I want it to look the dogs .
( I was going to drive them both , but unfortunately I can barely walk a few yards these days [even though its an auto] but at least I get to see it arrive at Leeds town hall )
