525TDS stuff - any use on an M20?
Andyboy
- Alpina Colada
I have a complete set of bits from an old 525tds - turbo, manifold, intercooler etc. Is it of any use for an M20? The turbo is quite small.
maxfield
The gearbox's are supposedly perfect to put plenty of torque through.
would the manifold be any use for an M50 in an E30 with a snail on top or do folks reckon there wouldn't be enough room?
Are the exhaust ports on a tds anywhere near the same size/ spacing as the M50 head?
maxfield
PS - You didn't get these from someone called James from Kirkby did you?
Jon_Bmw
- Dangerous when thinking
The manifold can be used on an m20, but the turbo exit is uncommon, its a 3 bolt design which some small mitshibishi turbos use. Td04/5 iirc. The head to manifold ports line up like a goodun though, so if you could convert the '3 stud' exit to t3/4 it could be useful?
Problem is, this day and age so many foriegn companies make up cheap 'stainless' alternatives I am not sure of their purpose anymore?
Andyboy
- Alpina Colada
No, they use an M20 style two bolt flange.E30BeemerLad wrote:would the manifold be any use for an M50 in an E30 with a snail on top or do folks reckon there wouldn't be enough room?
an ebay £99 special it shall be then
e30_Turbo
- Boost Junkie
The ebay mnifolds are so cheap most are sucked into buying them, they're not bad but there are better.
The td/tds turbo's are way to small and aren't holset qaulity so would melt with the temps petrol puts out. ( I sound like a holset snob, LOL )
If you get stuck with the bits let me know, my oilburner 325td could do with an IC and new turbo, it's gutless!! Have been told the IC alone is worth 20/30bhp, having driven a tds I'd still want more tho!
BadDave
The mani can be made to fit the M20
It requires a wee bit of work and an appropriate flange welded on for whatever(T3) turbo
I've got one that's ready to bolt on,which is currently surplus to requirements as well
Andyboy
- Alpina Colada
Make me a sensible offer, come and get it!e30_Turbo wrote:The ebay mnifolds are so cheap most are sucked into buying them, they're not bad but there are better.
e30_Turbo
- Boost Junkie
