"Here we go" more m42 info needed
robbo86
Alex, If you do it, wanna do a write up as I get confused over where you need to modify the loom?
Baz666
robbo86 wrote:Alex, If you do it, wanna do a write up as I get confused over where you need to modify the loom?
yeah alex can you do it next week, so i can copy you
GrindCulture
You don't need to modify the loom, just cut the wrap and re-route it so it reaches, then re-wrap it again. You can shorten it if you like but this isn't needed.
The most difficult bit is making the bracket.
Not in E30s any more
now im confusedBaz666 wrote:robbo86 wrote:Alex, If you do it, wanna do a write up as I get confused over where you need to modify the loom?
robbo86
Cut what wrap? sorry I can be rather dense when it comes to engines at times.You don't need to modify the loom, just cut the wrap and re-route it so it reaches, then re-wrap it again. You can shorten it if you like but this isn't needed.
Well loom or wiring for the engine... into the back of the coils, I dunno what its called, or am I totally lost now?now im confused what loom???
im confused about the bit about asking me to do a write up of some loom
robbo86
Sorry dude it was grindculture who it was on his to do list (the COP conversion) my bad
Hey grindculture when you do this ca you do a write up on it so I can copy you
lol i was getting confused, mind you it dont take much to get me confused
robbo86
know that feelingmind you it dont take much to get me confused
GrindCulture
Will do, once the car gets it's MOT sorted out it'll be all systems go for tinkering. Just wish I'd documented the M42 swap as it would have benefited a hell of a lot of people.
robbo86
Well if I am the next to do it then I will!
But here I have a few questions now, its hijacking time. I picked up my m42 from barry (bss325i) today and got a sneaky peak at his 318 project..... lovely
. But anyway. Nows I got the engine I want to know what bits I will need that I wont have?
I dont have a prop, will my m40 one work ok?
My car is currently an m40 with slushbox. So obviously a pedal box. Now the next question is, will the floor/bulkhead have to be holed in order to the linkages for the clutch to go through.
monkey
no you wont have to mad the floor . i think you can even use your pedal box and fit the clutch and brake pedals from the manual car , but swappaing the pedal maybe easyer you will then need the clutch master cylinder, pipe work to the slave cylinder , slave cylinder , clutch , flywheel , gearbox , manual prop , interior trim and gear lever .
Baz666
don't worry about it robbo about hijacking mate we are all trying to get the same job done
robbo86
Thanks. If I dont hove to maul the floor to get the clutch through, how does the pipework etc go through. I have the slave cylinder (I think) its a small deeley. I have all the box and everything as well, but I assume when you say manual prop I can't use the one I have got?don't worry about it robbo about hijacking mate we are all trying to get the same job done
Thanks guys
Baz666
I would say you would have the hole in the floor rob, as it would have been a lot easier when it came of the production line to do all the same chaises/ floor pans. ???
robbo86
Thats what I thought, typical german forward thining and al,l, but th father in law reckoned he knew better. This sounds like one for BrianmooreBaz666 wrote:I would say you would have the hole in the floor rob, as it would have been a lot easier when it came of the production line to do all the same chaises/ floor pans. ???
tim_s
I have coil on plug on mine. Not really worth the hassle tbh, makes it more of a pain to run a timing light on it (I have a spare lead for that), get the rocker cover off and changing plugs etc, the rubber boots on the coils split easily too, so def pros and cons. needs nyloc nuts on lots of stuff to stop them working loose with vibrations, and the alloy plate i used is bending slightly over time. Also been meaning to use washers to hold the plate on to spread the load a little.
pics (sorry they're a bit rubbish):
Baz666
does seem alot of hassle, thanks for the picture tho fella, might be something i`ll do in the future i think.
well its the start of a new week, starting tonight i`ll be ripping out the m42 ready to go in my cabby.
keep you posted
keep you posted
BigBavarian
Tha is a nice rocker cover and inlet manifold. What air filter are you running? Looks standard other than the extended pipe to the throttle body.
Richard
Richard
GrindCulture
No, it's ever so slightly too long.robbo86 wrote:I dont have a prop, will my m40 one work ok?
robbo86
Thanks.... guide price for m42 prop new and used anyoner couldnt find it from gsf
robbo86
am looking on realoem.... i would assume the driveshaft is the prop yes!!!
tim_s
Thanks! Air filter in those pics is just standard (well, k+n panel), and pipework is due to AFM removal (I run megasquirt which is SD - uses a MAP sensor).BigBavarian wrote: Tha is a nice rocker cover and inlet manifold. What air filter are you running? Looks standard other than the extended pipe to the throttle body.
Baz666
you lot lost me way back
robbo86
Again, anyone know what price an m42 prop would set you back
Baz666
robbo ask these boys www.bigbavarianbeauties.com you can ring them on 07858151197 Richard or Andrew
Baz666
update:
all going so smoothly at the moment.
i`v fund some m54 coils is there any perticular cc coils i need if i was going to do it.
GrindCulture
AFAIK All M54 coils are the same.
Baz666
found these m54 e42 coils but says there for the 330i
Thanks Grindculture
Thanks Grindculture
Baz666
could some tell me is it worth it or is it a big job to change the iS trottle body to a bigger one (325i)??
GrindCulture
325i TB wont work, you can open the iS throttle body up a little and adjust the butterflies so that WOT is a litle more true than it is from standard. Other than that there are'nt any alternatives to the throttle body unless you go down the ITB route.
Baz666
up date for tonight:
I have just spent the best part of the night trying to put in my iS engine to find that the shaft in the 318i box are not the same, the shaft on the 1.8 is a thinker diameter than the one in the iS box, which is very weird because everyone had told me there the same and even states in the book there the same.
so i have just spent out on a new clutch for the 1/8 box which will now be for sale as i need a iS clutch.
BigBavarian
Hows it going baz? Got it sorted and in yet?
Richard
Richard
monkey
i thought the clutches where the same on m40 an m42s . but i think there are two different size spigot bearings that fit in the crankshaft i think the difference is the hole in the centre of the bearing . that maybe why it wont fit
Baz666
The shafts in the gear boxs are differant, so it just easyer to use the iS box.
so now just got myself another new clutch for the iS box, yeah the clutch`es are differant because of the shafts in the box`es.
But all sorted now engine will go in monday or tuesday night just waiting on some bolts from BMW for the clutch.
raydon boy`s how is yours coming on i here your almost there, engine in and sprayed isnt it.
