Hartge H36 Project (E30 M3 with S38 M5 engine)
Post Fri Nov 28, 2008 5:51 pm
I would keep the rear end if you can just incase the shell you source need sections grafting in.
Theo
Just looked at realoem and the 3.6 e34 m5 uses the same pad as the e30 m3 and has a 300mmx20mm ventilated disc - so fairly certain they are m5 rear brakes. Quite probably m5 calipers on the front, but there's no custom adaptor to be seen.
Post Fri Nov 28, 2008 6:27 pm
Awesomeness, cheers Theo!
The pic of the bmw carrier attached to the custom carrier is not working for me though!! :(
Post Fri Nov 28, 2008 6:30 pm
Working now.. Odd :?
LondonTom
Post Fri Nov 28, 2008 8:29 pm
:bow:
Good luck mate
Theo
Post Sat Nov 29, 2008 7:40 pm
Right, todays mystery find was this;
No part number, has H 3.6 written on it like the ECU so perhaps it's something which is programmable? Any ideas?
Also got a first look behind the carpet at the front bulkhead, looks to be heavily modified. I'll take the dash and carpet out tomorrow and get a photo.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Nov 29, 2008 7:43 pm
So theo have u got the shell at urs or did u have to strip down at the breakers????
Theo
Post Sat Nov 29, 2008 7:44 pm
It's in my garage mate.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Nov 29, 2008 8:00 pm
ah wondere dcos some breakers are funny about releasing a complete shell from a write off car :cool:
Theo
Post Mon Dec 01, 2008 6:56 pm
Been dismantling the car a bit more this evening, the dash is out and in the bin, wiring looms are separated and the engine will be ready to come out shortly. The special washer jets are out, i'm going to copy these and fit a set to my track car which has a single skin GRP bonnet. I noticed on the OBC that it has a coding plug from an M3 sport evo which is strange. Where can I do a check with the vin number to tell what model m3 this was when it left the factory?
Anyway, enough rambling on. Here's a pic of the bulkhead molested by the fair hands of Herbert Hartge and co.
I've still not got an answer on that black box, any clues what it is?
Chris-W
Post Mon Dec 01, 2008 6:58 pm
Theo325 wrote:I've still not got an answer on that black box, any clues what it is?
Where was it plugged in and where do the wires go?
Theo
Post Mon Dec 01, 2008 7:15 pm
I was above the ECU and has five wires coming from the plug all leading into the engine loom.
brown/orange, blue/black, green/purple, black and brown/black.
barryj
Post Mon Dec 01, 2008 10:09 pm
I think its a module to eradicate the need for the M5's imobiliser that is activated by a chip built into the key, does your car have a normal E30 non chipped key by any chance?
Theo
Post Mon Dec 01, 2008 10:24 pm
Yes it has a normal e30 non chipped key. I shall do some wire tracing and see where they lead.
Post Mon Dec 01, 2008 11:04 pm
barryj wrote:I think its a module to eradicate the need for the M5's imobiliser that is activated by a chip built into the key, does your car have a normal E30 non chipped key by any chance?
I didn't think E34 M5's with the S38B36 had EWS. The B36 predates the EWS era does it not?
tomson
Post Mon Dec 01, 2008 11:22 pm
Early B36's yes but I think later B36's did have EWS, same goes for S50B30 - yours has EWS Barry but I've seen early E36 M3's without it....
tomson
Post Mon Dec 01, 2008 11:23 pm
Cracking project BTW Theo !
Post Mon Dec 01, 2008 11:27 pm
Green/Purple is a fuel pump feed wire, is there two of these?
tomson
Post Mon Dec 01, 2008 11:28 pm
DanThe wrote:Green/Purple is a fuel pump feed wire, is there two of these?
Here's a man that will know!
Post Mon Dec 01, 2008 11:29 pm
Does look EWS module shape/pins but if the key doesn't have a chip....
Post Mon Dec 01, 2008 11:32 pm
My S50 doesn't have EWS either..
EWS didn't come in (well on S50's at least..) untill '96
tomson
Post Mon Dec 01, 2008 11:33 pm
Could be so the car doesnt need EWS Dan as said above ? ?
Post Mon Dec 01, 2008 11:37 pm
But surely the engine was put together before 95, which was AFAIK when EWS came in
Post Mon Dec 01, 2008 11:41 pm
tomson
True, either way it must have been built before that unless this car was a late conversion and not done when first new ? ?
tomson
Post Mon Dec 01, 2008 11:43 pm
"MULTIPLE START INTERRUPTION" ? ?
Theo
Post Mon Dec 01, 2008 11:47 pm
I did see that multiple start thing when browsing realoem and wondered if it could be related. I asked about this thing on a 5 series forum and no one has recognised it. And it also has H3.6 written on it like the ECU which suggests it's not a standard component.
Post Tue Dec 02, 2008 12:01 am
my educated guess to the black box mystery would be the 155mph delimiter maybe?
Theo, go to your main dealer with the chassis number or ring boybimmer as he can check on the german system and find out the exact spec of the base car for you.
Immense
Theo
Post Tue Dec 02, 2008 1:53 pm
I think the little module on the back of the ECU is the speed delimiter, this black box remains a mystery.
I've been removing the air conditioning system this morning (heater box was tricky thanks to the modified bulkhead) turns out the car has the very rare automatic heater control so it will maintain a constant temperature on it's own accord. I've always wondered what that little vent in the heater control panel was for, seemingly it's for a temperature sensor for the automatic heater control.
Post Tue Dec 02, 2008 2:08 pm
Yup that little knob was for climate! Very rare :cool:
zimmerbimmer1
BMW Parts Meister
Post Tue Dec 02, 2008 2:21 pm
EWS came out from jan 1995 best way to check if the key blade is silver (non ews) or bronze colour (with ews).
Post Tue Dec 02, 2008 6:01 pm
The B38 replaced the B36 in 92/3 did it not? If thats the case and EWS didn't come out till jan 95 then surely that black thing is nothing to do with EWS as the engine used for the conversion is a B36?
Theo
Post Tue Dec 02, 2008 6:09 pm
It's a standard silver key, so looking unlikely that it's EWS related. I didn't get round to tracing the wires today, that can wait until the engine is out and on a stand.
I've managed to get the engine number written down and want to cross reference it against data on the net, anyone got a link for such data?
Post Tue Dec 02, 2008 6:13 pm
EWS was years after this turd rolled out you people!
climate, nice it actually works too theo!
keri-WMS
Post Tue Dec 02, 2008 8:18 pm
Theo325 wrote:Anyway, enough rambling on. Here's a pic of the bulkhead molested by the fair hands of Herbert Hartge and co.
Nice! Reminds me of an old RWD Escort me or Gareth had, can't remember which one or our many (4-door Mk2 or 2-door Mk1 Mexico rustbucket) but that area of the firewall was made out of a STOP road sign!
Hint from a real brake geek: look up the part numbers on the brake pads themselves... winkeye
