new member needs some advice.
blacksoul
Post Sun Jul 10, 2005 1:21 am
hi guys found this site a few days back and must say its great. anyway i have driven e30 motors now for the last 3 years. my first was a diamond black 318i that was mint!!! 89 plate with 71k on the clock from jersey:) anyway in march this year a golf gti decided to end my run with this motor and took out my back quater and pretty much the boot aswell. i have now purchased a black 325i cabby 87 plate its a quick drive full of mods. will upload pics when i get 2 mins. anyway after driving for about 20 mins on the road bypass ect...:) i decided to indulge in a mcdonalds to my horror as i waited in the drive thru. the temp gauge was rising and rising you get the picture it went almost to red so i chucked heaters on full and that bought me enough time to get the car parked and to cool him down. since then its been flushed there is no mixing of oil and water the radiator looks like its had better days but it does not overheat when idle or when driving only after its been driving fast ect.. and then idle. any advice from you guys would be a great help. cheers martin south wales.
Sjoerd320i
Post Sun Jul 10, 2005 1:25 am
warm welcome mate :D
maybe a fudged up viscous coupling for the fan?
seems the most logical thing to me as there is not oil/water mixing so probably not a cracked head, not sure tho :roll:
blacksoul
Post Sun Jul 10, 2005 1:47 am
hi cheers for the welcome. the engine to be honest looks and feels great. the fan has a few chunks taken out of it but looks like its working. and evrything looks realy clean under the cap. we are thinking maybe a blocked radiator? but not sure. i removed the thermostat today and then foolishly tested against my brother in his 325 sport just to get the car upto temp. when we returned the neddle again started to creep. anyone else had this exact problem? cheers martin.
Sjoerd320i
Post Sun Jul 10, 2005 1:50 am
try folding up a news paper and when the fiscous fan is on try stping it with the foldet newspaper and if it stoppes the coupling is buggerd if it rips the paper to bit I'm afrais I can't realy help you :(
Post Sun Jul 10, 2005 1:59 am
do u get lots of white smoke when the engine is cold out of the exhaust when driving for say the first 5 miles?
Sorry to say but the 2.5 has a weakness for cracking heads when the coolant is not changed every 1-2 years in it's lifetime. But it could be the viscous so worth doing the newspaper trick first to see if it is knackered as this won't be helping things!!!!
blacksoul
Post Sun Jul 10, 2005 2:19 am
hi no smoke at all from the car. to be honest i dont think it will overheat standing around for a long long time. its only after a drive and then when its ticking over it starts creeping. ill try the newspaper thing. can someone point out the things to change if the newspaper thing dont work. and also any signs other than oil and water mixing if its a cracked head?
browny
Post Sun Jul 10, 2005 3:32 am
Hey all, for my two cents worth, have you thought about the water pump? My 320 had a similar problem and after chasing around with sensors/thermometers etc, it turned out to be the water pump. I don't know how you check it though :?
Post Sun Jul 10, 2005 9:43 am
Stop worrying the poor bloke! These are classic syptoms of hot weather, a bit of heat soak, and a duff viscous coupling.
Get the car up to temp and let it idle with the bonnet closed. After a minute or two, as the temp begins to creep up, you should hear the sound of rushing air as the fan clutch locks up and drives the fan hard. Rev the engine a little, and you can easily hear if it's engaged.
Keep an eye on the temp gauge all the time of course, and don't cook it.
Get the fan blades changed as well if they are chipped - they have been known to disintegrate.
Richy325iTouring
Post Sun Jul 10, 2005 10:27 am
blacksoul wrote:hi cheers for the welcome. the engine to be honest looks and feels great. the fan has a few chunks taken out of it but looks like its working. and evrything looks realy clean under the cap. we are thinking maybe a blocked radiator? but not sure. i removed the thermostat today and then foolishly tested against my brother in his 325 sport just to get the car upto temp. when we returned the neddle again started to creep. anyone else had this exact problem? cheers martin.
You have put the thermostat back in havent you.
The biggest problem you seem to have is the viscus fan get a new one and that should cue your problem
chippenham_touring
Post Sun Jul 10, 2005 6:43 pm
Hi
I had exactly the same problem last week, changed the viscous coupling -part cost less than Ԛ£40 and took less than an hour. Even in todays heat wave the car runs cooler. Jetblasted the rad and the heat exchanger for the air con and all problems were cured!!
blacksoul
Post Sun Jul 10, 2005 9:15 pm
hi cheers fpr your advice guys. i tried stoping the fan today and it ripped paper and did not stop so i guess thats not the problem. the water pump could be something to look at. but my bros sport is fine in this weather his needle sits just under half way all the time. also how do we get pics of our motors on here guys? anyone help? cheers martin.
Simon
Post Sun Jul 10, 2005 9:19 pm
Hi Martin, where abouts in South Wales you from then?
Try here for uploading pics..
http://www.imageshack.ws/
Sjoerd320i
Post Sun Jul 10, 2005 9:21 pm
about the pics, host them on www.imageshack.us
blacksoul
Post Sun Jul 10, 2005 9:24 pm
hi thanx for the pics link. me and my bro who registered yesterday i think are from cwmbran just outside newport south wales.
blacksoul
Post Sun Jul 10, 2005 9:27 pm
lol think we are from make that i know we are from cwmbran sorry sweaty sticky fingers haha:)
Sjoerd320i
Post Sun Jul 10, 2005 9:28 pm
:lol: :lol:
Simon
blacksoul wrote:lol think we are from make that i know we are from cwmbran sorry sweaty sticky fingers haha:)
I had to read it twice :lol:
Keep an eye on the meets section, we have some regular meets down here in South Wales, normally meet at Dowlais Top near Merthyr, not too far from you.
blacksoul
Post Sun Jul 10, 2005 10:31 pm
yeah cheers will do. here is a link to a pic of my new cabby hope it works > URL=http://img265.imageshack.us/my.php?imag ... 0038zm.jpg]Image[/URL]
Sjoerd320i
Post Sun Jul 10, 2005 10:36 pm
use the "direct link to pic" one :wink:
blacksoul
Post Sun Jul 10, 2005 10:46 pm
Sjoerd320i
Post Sun Jul 10, 2005 10:47 pm
perfect just put the img tags around it :wink:
Richy325iTouring
Post Sun Jul 10, 2005 10:49 pm
i keep aneye out for you i work onthe polo grounds and live in newport
Chaos
Post Sun Jul 10, 2005 10:56 pm
u need to put [img]thentheurlwithnospaces[/img]
and your pics shud work.
few of us from south wales on here now m8, come to the next meet and say hi.
Chaos
causing havoc and mayhem wherever i go
blacksoul
cool. was driving around new inn tonight. anyway dont think i can do much more with the pics i have reached my tech limit lol. you may have seen my brothers silver 325i sport going around its very clean!!!!has alpinas ect..
Richy325iTouring
Post Sun Jul 10, 2005 11:00 pm
ive seen a silversport on alpina reps a few times
come inriverside newport one in a while slides round the top and goes back out again
blacksoul
Post Sun Jul 10, 2005 11:03 pm
hehe yeah thats probley it.
Richy325iTouring
Post Sun Jul 10, 2005 11:04 pm
woundered whos it was
i think i should have bought a keyboard today instead of a mouse drrrrrrrrrrrrrr
