my e30 3.6 td project proper driving vid with exhaust page 7
BigBavarian
Post Fri Nov 14, 2008 6:49 pm
Look forward to it mate. Not a bad top speed either with such a big lump up front.
Richard
336tdse
Post Sat Nov 15, 2008 4:50 pm
well im chuffed :D got the engine in there today and made the engine mounts. the engine sits same angle as the original bmw engine just looks higher up front as its a much longer engine. just needs slight fettling with a hammer to bulkhead for starter to fit only about 10mm though. just gotta mark the sump for oil pan and take engine out for flywheel balancing and finish gearbox mountings and final build for the 3rd and hopefuly last engine install. a few pics
BigBavarian
Post Sat Nov 15, 2008 5:17 pm
That is one big chunk of engine! Did you have to cut the front panel off to get it in there?
Richard
336tdse
Post Sat Nov 15, 2008 5:26 pm
BigBavarian wrote:That is one big chunk of engine! Did you have to cut the front panel off to get it in there?
yeah gonna make a new panel around the engine an unboltable one :)
Baz666
Post Sat Nov 15, 2008 5:28 pm
I would say so look where the fan is, way passed the bloody lights.
going to be nice when finished.
town325i
Post Sun Nov 16, 2008 8:58 am
have you had any thoughts on where the rad i going to fit?
336tdse
Post Sun Nov 16, 2008 11:49 am
town325i wrote:have you had any thoughts on where the rad i going to fit?
just where it needs to fit in front of the fan il then just build a frame around it
336tdse
Post Sun Nov 16, 2008 12:39 pm
done a bit of digging my engine is a hr 692 ht exactly same engine code as fitted in an italian sports car covini t40. intercooled and overboost 225 bhp at 4300 rpm 0 - 62 7.5 seconds and top speed of 146 mph in a 1350 kg car. i thought the engine would be well detuned for reliability in a boat :) nice to know theres more power available easily if i want it winkeye
Post Sun Nov 16, 2008 12:48 pm
324td wrote:done a bit of digging my engine is a hr 692 ht exactly same engine code as fitted in an italian sports car covini t40. intercooled and overboost 225 bhp at 4300 rpm 0 - 62 7.5 seconds and top speed of 146 mph in a 1350 kg car. i thought the engine would be well detuned for reliability in a boat :) nice to know theres more power available easily if i want it winkeye
Just found out that the military spec Lamborghini LM-003 had the same engine.
An LM-003 was also built; in fact, it was an LM-002 with a turbo charged diesel engine (HR/692-HT) installed in it, because the military required diesel propulsion. This engine, supplied by VM of Cento, with 3590 cc displacement producing 150 bhp at 4200 rpm and connected to a ZF five-speed gearbox was too underpowered for the heavy vehicle, and the project was abandoned
336tdse
Post Sun Nov 16, 2008 1:31 pm
im not suprised it was underpowered must of weighed 4 ton at least ! im surprised they even tried it tbh. im trying to find an engine dyno power plot for the engine in standard form but cant find one yet ?
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sun Nov 16, 2008 1:32 pm
looks wicked with that engine in the bay :twisted:
336tdse
Post Sun Nov 16, 2008 4:11 pm
from what else i can gather 692 hi9 is identical except intercooled and thats 170 bhp 260 lbft. im gona defo fit an intercooler in when i make the rad mount up.
336tdse
Post Sun Nov 16, 2008 4:51 pm
with an intercooler i should be up to this spec :
town325i
Post Sun Nov 16, 2008 9:10 pm
if you keep the fan on will you be able to fit the rad where its ment to go?
GrindCulture
Post Sun Nov 16, 2008 9:18 pm
I think it's going to be one hell of a job to keep that thing cool, let alone work out all the charge cooling gubbins for the turbo. But then again I hightly doubted it would even fit in the bay, but you managed it. :thumb: to you, you mentalist!
Not in E30s any more :(
336tdse
Post Mon Nov 17, 2008 4:14 pm
town325i wrote:if you keep the fan on will you be able to fit the rad where its ment to go?
no the rad mounting is behind the fan now and been cut out anyways. the new rad is 4 times bigger than the original must be 100 mm deep. itl be so easy bit of plate underneath boled to a new crossmember and a mount plate at the top job done :). i do love a bit of fabricating it wont win any concourse awards but itl do what i need winkeye
336tdse
Post Mon Nov 17, 2008 4:17 pm
GrindCulture wrote:I think it's going to be one hell of a job to keep that thing cool, let alone work out all the charge cooling gubbins for the turbo. But then again I hightly doubted it would even fit in the bay, but you managed it. :thumb: to you, you mentalist!
dont need to run all that crap on the engine in the pic mate just a 4x4 cosworth intercooler sat next to the rad will be perfect winkeye engine is out again now just gotta finish of gearbox and sump and final engine fit hopefully saturday 8O
336tdse
Post Mon Nov 17, 2008 4:21 pm
looking at the power graph theres loads of torque for 2000 to 3000 revs and with my new crownwheel and pinion just by driving in that rev range will take me from 0 to 102 mph winkeye
robbo86
Post Tue Nov 18, 2008 12:32 am
To be followed by a frankenstein-like "ITS ALIIIIVVEEEE" moment
336tdse
Post Tue Nov 18, 2008 6:22 pm
i hope so mate if it works.
got gearbox finished today and starter on and sealed at the back. started on the sump got oil pick up relocated and pan resting about where i want it. hopefully have sump finished tmrw if all goes to plan.
tbh im happy with how its going only gearbox giving me slight concerns but it will be geting some testing as soon as its driveable to make sure its going to work ok. spent so far £75 on machining and £20 on a fuel pressure reg. must be knocking on to 100 hours of work time though :mad:
336tdse
Post Wed Nov 19, 2008 6:39 pm
got sump done and on :) few pics
Post Wed Nov 19, 2008 6:41 pm
cannot wait to see this in the car :cool: :cool:
keep up the good work :thumb:
Jon_Bmw
Dangerous when thinking
Post Wed Nov 19, 2008 6:43 pm
Seriously impressive, but so, so much effort. You are obviously fairly skilled, you could have pioneered the first 330D engined e30, instead you have a very heavy underpowered boat anchor! :P :mad:
Keep the pics coming, its certainly a mad project. Respect. :)
Post Wed Nov 19, 2008 6:45 pm
3.0d swap has already been done into a Tech 1!!
1an
Post Wed Nov 19, 2008 6:46 pm
Jhonno wrote:3.0d swap has already been done into a Tech 1!!
bet all the purists love that one, diesel and a tech 1
336tdse
Jon_Bmw wrote:Seriously impressive, but so, so much effort. You are obviously fairly skilled, you could have pioneered the first 330D engined e30, instead you have a very heavy underpowered boat anchor! :P :mad:
electrics on modern engines are way over my head mate. its a headache i cant be doing with. i just hope my sump doesnt leak and my gearbox doesnt fall off :mad:
336tdse
Post Wed Nov 19, 2008 7:16 pm
this is a test for me tbh ive rebuilt a chevy and a few cat engines but this converting stuff is new to me, has cost £100 so worth a punt for the learning curve i think. im gonna get engine in and make rad mounts tmrw. hopefully should be running in the car by saturday all fingers crossed :D
Jon_Bmw
Post Wed Nov 19, 2008 7:21 pm
Fair enough! £100, thats pretty good. Are you expecting good things from the economy, or is it just a fun car that is going to plume out black smoke all the time? 8)
BigBavarian
Post Wed Nov 19, 2008 7:25 pm
Dont think fuel economy will be that bad, you could probably run it on heating oil!
Richard
336tdse
Post Wed Nov 19, 2008 8:27 pm
Jon_Bmw wrote:Fair enough! £100, thats pretty good. Are you expecting good things from the economy, or is it just a fun car that is going to plume out black smoke all the time? 8)
just something different its just a car and engine i have lying around and thought id try use them.
town325i
Post Wed Nov 19, 2008 10:37 pm
he gets free derv too
336tdse
Post Thu Nov 20, 2008 6:34 pm
well got the engine in today gear lever is in original position. starter is on. im half way through mounting the radiator :D il take some pics tmrw shes on a serious nose dive at the minute though :cry: im gona just try it first and make sure everything works ok, if it does then im gonna need some height and dampening adjustable front suspension. im gonna be a dad in about a weeks time im trying to just get it running and moving before shes born as play time will be much less when my daughters here :D
Post Thu Nov 20, 2008 6:38 pm
Looking forward to seeing the pics 8)
336tdse
Post Fri Nov 21, 2008 7:20 pm
rad is in and motor is on the key now :D tryed manual fuel pressure reg but cant get pressure low enough from fuel pump so gotta replace it with electric lift pump and bolt prop on and try and drive it tmrw :mad:
Post Fri Nov 21, 2008 8:09 pm
wow, rapid progress made with this
If you do ever decide to move those wheels on let me know as i have a set here but one is quite bent :(
Do you have to use spacers on the front? Don't suppose you have 5 of the wheels and wanna sell the spare? winkeye
