ebay hid kits
If you go for the conversion kit it may be different, the ones that are advertised for about £60. I just replace the bulbs in mine and they seem to work so not too fussed. I'm just trying to find out weather you can intsall HID bulbs in the angel eyes rings.
As mentioned above, the ones you have aren't HID/Xenon lights matey, they're just a different coloured bulb!ImysE30 wrote:I've got them fitted in all my headlights
The link I posted near the top of the thread details a HID kit complete with ballasts etc to fully convert your car to HID lights for under £40.
NayC - There may well be a way to do the full beams too but general consensus is that if you have HIDs in your dipped beam, you won't ever need the main beam as the light output is so strong from the HID dipped beam!
aj_mckay wrote:these are the ones i'd go for...
http://cgi.ebay.co.uk/HID-Conversion-Ki ... m153.l1262
- Brianmoooore
Mr. ImysE30 - You do not have HID headlamps! You have 'pretend' ones that are probably dimmer than the originals, since they are blue (ish) simply by filtering out the red end of the spectrum!! HIDs are a discharge lamp, that strikes on a voltage of a thousand or two volts.
HIDs aren't really suitable for main beam use, as 1) frequent switching shortens their life dramatically, 2) they have a warm up time of a few seconds.
Cars that have HID main beams usually use a mechanical shutter arrangement to control the beam.
So its not advisable to get the main beams.
Are these good ones then?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %26ps%3D42
Uni is killing the project.
NayC, those are the very ones i have so im saying yes, they're good
But they do not like being flashed so are unsuitable for main beams, you will just knacker them.
The E30 main beam units have exceptionaly good reflectors so a decent pair of normal halogen bulbs will do, as i said on page 1 i used OSRAM cool blues which are not that expensive and are suposed to be about 4000k colour temp...
Heres a pic compareing them to normal halogens in the front fogs so you can see the contrast.
Ooh nice. What bulbs did you need from that guy. He says you need to state the blubs you want and the colour and it doesn't make much sense. I know i want 4300k bulbs but is there a certain type to be used in e30s?
zimmer-320i
- Contact:
so osram 43k h1 bulbs do the trick? i hate the dull light these lights give off!!
Good good. I think i'll be purchasing some today...
And then some fake bulbs for the head beams to get rid of that nasty yellow light. Anyone know some good aftermarket bulbs for the main beams? and are the fog lights the same?
BigBavarian
- Contact:
After reading all this, im going to take the advise and go for a set of 4300k,
Thanks everyone been most helpfull!
Richard
Richard
Demlotcrew
Actually there is about 30% difference in 'factual' light output between 4.3k and 6k bulbs.mattyb240 wrote:Exactly. Factual light output between 4300K an 6000K isnt that much different. To be honest I think it could be the way the camera took the light. Although next time I will be going for 4300K over the 6000K.Brianmoooore wrote:A colour temperature of 6000K is a colour temperature of 6000K.town325i wrote:there are two different types of 6000k bulbs one set are blue and the other are ice white i no this becuase i have both
If you have two bulbs rated at 6000K which are a different colour to each other, one of the manufacturer's is lying!
town325i
they are both labled up as 6000kBrianmoooore wrote:A colour temperature of 6000K is a colour temperature of 6000K.town325i wrote:there are two different types of 6000k bulbs one set are blue and the other are ice white i no this becuase i have both
- Brianmoooore
Anyone who thinks H1 halogen lamps are yellow, obviously doesn't remember 45/40W tungsten headlamp bulbs!NayC wrote: for the head beams to get rid of that nasty yellow light.
Brianmoooore... i dont even know what you mean when you say '45/40W tungsten headlamp bulbs'. How on earth would i remember? P.s. i have pretty yellowy bulbs, thats all i know about headlamps. I dont have much of an interest in knowing different types of lights, how they're wired and what not..... i dont even know what H1 means but all as i know now is thats the type of bulb fittement you need on an E30.
Morat
x2e30cossie wrote:I cannot believe how cheap these kits are.
I can't recommend them enough!
- 323iNathan
Slightly off topic, but has anyone installed 3000K lights in they're fogs?
If so how's it look, how do you like them??
- Brianmoooore
10k and 12k are far less bright than 4.5k or 6k, and will probably get you pulled for showing a blue light.e30cossie wrote:Has anyone brought a 10,000 or 12,000 kit or are they too bright for the road or fail m.o.t
what brian said.e30cossie wrote:Has anyone brought a 10,000 or 12,000 kit or are they too bright for the road or fail m.o.t
the k - rating is the colour , not the actual temperature or light output. a set in the 4000k range will give the cleanest light that appears brightest to the human eye, so for actually seeing where you're going it's the best to go for. 6000k has a slight blue tinge, without killing the visible light output too much, so is the one people go for if the wan more of an 'hid' look allong with improved lighting.
any higher than 6000 and they start getting very obviously blue, the 12000 must be almost purple, you'll start attracting unwanted attention, annoy other road users and have lights that don't work any better than the standard ones!
cheers,
harry
harry
Then we got sealed beam units that was an improvement! they stayed clean!Brianmoooore wrote:Anyone who thinks H1 halogen lamps are yellow, obviously doesn't remember 45/40W tungsten headlamp bulbs!NayC wrote: for the head beams to get rid of that nasty yellow light.
Coffin dodger still driving a
Crusher dodger
Crusher dodger
cool_ram_in
Does anyone know if the phaseII headlights like the ones below work fine with hid?
i´m asking this because i found that there´s some headlights designs for halogen bulbs that originate glare when converted to hid.
watch this please: illegal hid conversion kits explained-
http://www.youtube.com/watch?v=yVuSSdZN ... re=related
What do you guys (and girls) think about this?
- Brianmoooore
The outer headlamps in your pic have a metal shield which provides the beam control and cut off, and will work absolutely fine with HID lamps. These are the ones that you must use.
